Genuine Toyota Oil Filter & Related Parts
2011 Toyota Update
Oil Filter |
Oil Filter |
YEAR |
ENGINE |
PART # |
CUST ID # |
FILLER CAP PART # |
DRAIN PLUG PART # |
1991-92 |
4 Cyl. (2TZFE) |
90915-YZZG1 |
FO-8 |
12180-73011 |
90341-12012 |
1996 |
4 Cyl. (2TZFE) |
90915-YZZG1 |
FO-8 |
12180-76011 |
90341-12012 |
1994-97 |
4 Cyl. (2TZFZE) |
90915-YZZG1 |
FO-8 |
12180-76020 |
90341-1201 |
Re: Genuine Toyota Oil Filter & Related Parts
Where did you find this information? I'm not familiar with the 90915-YZZG1. Toyota used to (and I suspect still does) spec the 90915-YZZD1 filter for use on the Previa. I recently switched to the 90915-YZZD3, which has the same OD as the YZZD1, but is a few inches longer with more filter media inside. The fit of the longer 90915-YZZD3 is fine on the Previa. I'll have to look at a YZZG1 the next time I'm at my dealer's part department. Eric
Yeah, Toyota seems to change their numbers every few years and/or the parts guys just hand out whatever they have the most of. So far I've been given 08922-02011, 90915-YZZD1, & 90915-YZZD3. I prefer the 90915-YZZD3 as its bigger (more filter surface area inside). Tim
PS: They've never given me the YZZG1 .
