- 0
Electrical problem, ignition switch?
Fist time posting to site so let me know if I’m in the right place.
problem:
no blinkers, power windows, heater, wipers, rpm gauge.
had this problem before after replacing ignition switch it fixed it. Not this time.
Checked and replaced AM1 fuse, and checked other neighboring.
Power getting through both links near battery.
all fuses in fuse block look good.
Actually replaced ignition twice in a row because failed continuity test.
van starts and drives fine.
I’m drawing a blank on where to look next.
any wisdom would be awesome!!!
thanks in advance
