    Burntboot
    Re: Tough to start after rain, and oil in one spark plug
    Oil in a spark plug well won’t cause a starting problem in the rain.
    There is only one coil and it lives inside the distributor.
    There is a thread in history that is almost identical to this one....
    Burntboot 12-05-2021, 09:15 AM Go to last post
    Burntboot
    Re: Steering Wheel Shenanigans
    If all these problems are only occurring since your repair attempt then go back over everything you have touched. You have probably missed a connection or something. It’s easy to do, especially if...
    Burntboot 12-05-2021, 08:56 AM Go to last post
    Re: a ghost in the headlight circuit
    That harness runs down the underside of the steering column. You will need to take off the column cover (on the underside where the column enters the dash). There are 4 Phillips head screws holding...
    timsrv 12-05-2021, 05:16 AM Go to last post
    LeonDaneko
    do you know where I might find this blue plug?
    LeonDaneko 12-05-2021, 01:21 AM Go to last post
    89van
    Haven't had time to check since this thing gets used everyday. Issues are still persisting but I've noticed toying around with the controls and what still needs to be done/checked:
    The Hi-beam...
    89van 12-04-2021, 11:46 PM Go to last post
