    Tx86
    Re: 1986 2wd Van Midland TX
    Last price update $1000 obo if I don't sell by next week I'll start pulling the injectors
    Tx86 05-06-2021, 03:58 PM Go to last post
    thepuzzlemaster
    Re: Overheating & gurgling behind dash
    I can't help you with actually fixing your problem, but a tactic I've used in the past on a vehicle that would overheat to help prolong it's drivability, is a trick I learned about on CarTalk. If the...
    thepuzzlemaster 05-06-2021, 02:46 PM Go to last post
    ccrnnr9
    I have a '96 rwd with about 199k on it. I bought it from the previous and original owner who had the head gasket replaced around 30-40k miles back. I put about 7k on the van and recently after...
    ccrnnr9 05-06-2021, 11:00 AM Go to last post
    hiace87
    Re: Oil leaking from spark plug housing
    boogieman thanks once again. Brilliant, just what i was expecting. I'm not sure if i have the correct part number.
    Is this the correct part here?
    11191 – 22010
    hiace87 05-05-2021, 01:42 PM Go to last post
    boogieman
    ooof those are no good anymore, probably from repated over torquing of the plugs...the lower hole should only be large enough for the plug to pass thru and hold down the whole tube...make sure the...
    boogieman 05-05-2021, 12:51 PM Go to last post
