ToyotaVanTech Forums - Powered by vBulletin
  • Register
  • Help
  • What's New?
  • Articles
    • TVT Vanwagon Owner's Manual
    • TVT Previa Owner's Manual
    • Tim's Tech Tips
  • Forum
  • Blogs
  • Advanced Search
  • Library
  • Home
  • Van Technical Information
  • TVT Van Service Manual
  • Cooling System
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
  • Section Widget
        • Maintenance
        • Engine Mechanical
        • Emission Control Systems
        • EFI System
        • Cooling System
        • Lubrication System
        • Ignition System
        • Starting System
        • Charging System
        • Clutch
        • Manual Transmission
        • Automatic Transmission
        • Transfer
        • Propeller Shaft
        • Front Axle and Suspension
        • Rear Axle and Suspension
        • Brake System
        • Steering
        • Body — Electrical System
        • Body
        • Air Conditioning System
        • Service Specifications
        • Standard Bolt Torque Specs
        • Electrical Wiring
      • Tech and Performance Mods (Vanwagon)
      • Custom Van Projects
      • TVT Previa Service Manual
      • Tech and Performance Mods (Previa)
      • Custom Previa Projects
    • Van Parts
      • Vanwagon Collision Catalog
      • OEM Van Part Numbers and Availability
      • Aftermarket Part Sources — Vanwagon
      • Parts Interchangability for Vans
      • Van-compatible Accessories
    • Previa Parts
      • Previa Collision Catalog
      • OEM Previa Part Numbers and Availability
      • Aftermarket Part Sources — Previa
      • Parts Interchangability for Previas
      • Previa-compatible Accessories
    • Van Historical Information
      • OEM Van Dealer Literature (links)
      • Vanwagon — external information links
      • Vanwagon articles and videos
        • TVT member articles — Vanwagon history
        • Vanwagon articles and press releases
        • Videos — Vanwagon commercials
        • Videos — Vanwagon, other
    • Previa Historical Information
      • OEM Previa Dealer Literature (links)
      • Previa — external information links
      • Previa articles and videos
        • TVT member articles — Previa history
        • Previa articles and press releases
        • Videos — Previa commercials
        • Videos — Previa, other
    • Tim's Tech Tips
  • Categories Widget (Show All)
  • Cooling System
    Replacing your van's thermostat
    llamavan
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    Modeling for all but one of the following pics is PJvan, a 1984 LE 2WD.
    New parts:
    Thermostat
    Read More Read More
    Getting to know all the coolant hoses of your Vanwagon!
    llamavan
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    A tour of the cooling hoses in the van, with part numbers!
    Note: I'm posting this now, by popular demand, ...
    Read More Read More
    Amazon Prime
    Re: HiAce 1KZ Timing Belt Failure
    Ok, I've gotten the head off and have a pretty good idea of the extent of the damage.
    The cam is snapped in 2 places. You can see dents from the cam lobes on the intake valve shims of cylinders...
    Amazon Prime 06-29-2022, 11:34 PM Go to last post
    Re: Engine Stalls when I hit a puddle in the rain
    I think a banana dance is in order :dance2::dance1::dance1::dance1::dance2: :thmbup:
    timsrv 06-29-2022, 12:05 AM Go to last post
    Temassi
    It is an '86. That looks exactly like the part that I need. Thanks a bunch, I really appreciate it!
    Temassi 06-28-2022, 07:33 PM Go to last post
    Previologist
    That power-in line was the only one I wasn't able to get off when I greased the others a few days ago, because I didn't take the coil off when I did it. Today I took the coil off, liberally greased...
    Previologist 06-28-2022, 05:23 PM Go to last post
    originalkwyjibo
    That's the power steering pressure hose that goes from the pump to the steering rack. Assuming this is for the 86 listed in your profile, I would think this is more likely the appropriate hose....
    originalkwyjibo 06-28-2022, 05:21 PM Go to last post
    Make a Donation
  • Contact Us
  • ToyotaVanTech
  • Archive
  • Top
Powered by vBulletin® Version 4.2.5
Copyright © 2022 vBulletin Solutions Inc. All rights reserved.
2010 - ToyVan Support Group LLC
