ToyotaVanTech Forums - Powered by vBulletin
  • Register
  • Help
  • What's New?
  • Articles
    • TVT Vanwagon Owner's Manual
    • TVT Previa Owner's Manual
    • Tim's Tech Tips
  • Forum
  • Blogs
  • Advanced Search
  • Library
  • Home
  • Van Technical Information
  • TVT Van Service Manual
  • Starting System
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
  • Section Widget
        • Maintenance
        • Engine Mechanical
        • Emission Control Systems
        • EFI System
        • Cooling System
        • Lubrication System
        • Ignition System
        • Starting System
        • Charging System
        • Clutch
        • Manual Transmission
        • Automatic Transmission
        • Transfer
        • Propeller Shaft
        • Front Axle and Suspension
        • Rear Axle and Suspension
        • Brake System
        • Steering
        • Body — Electrical System
        • Body
        • Air Conditioning System
        • Service Specifications
        • Standard Bolt Torque Specs
        • Electrical Wiring
      • Tech and Performance Mods (Vanwagon)
      • Custom Van Projects
      • TVT Previa Service Manual
      • Tech and Performance Mods (Previa)
      • Custom Previa Projects
    • Van Parts
      • Vanwagon Collision Catalog
      • OEM Van Part Numbers and Availability
      • Aftermarket Part Sources — Vanwagon
      • Parts Interchangability for Vans
      • Van-compatible Accessories
    • Previa Parts
      • Previa Collision Catalog
      • OEM Previa Part Numbers and Availability
      • Aftermarket Part Sources — Previa
      • Parts Interchangability for Previas
      • Previa-compatible Accessories
    • Van Historical Information
      • OEM Van Dealer Literature (links)
      • Vanwagon — external information links
      • Vanwagon articles and videos
        • TVT member articles — Vanwagon history
        • Vanwagon articles and press releases
        • Videos — Vanwagon commercials
        • Videos — Vanwagon, other
    • Previa Historical Information
      • OEM Previa Dealer Literature (links)
      • Previa — external information links
      • Previa articles and videos
        • TVT member articles — Previa history
        • Previa articles and press releases
        • Videos — Previa commercials
        • Videos — Previa, other
    • Tim's Tech Tips
  • Categories Widget (Show All)
  • Starting System
    Starter clicks but won't crank!
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    There are several possibilities here, but before doing anything, inspect your battery cables and terminal ends to make sure ...
    Read More Read More 9 Comments
    Re: diagnosing a headgasket failure
    If you got another fan I'd probably try that 1st. If your funds are limited then go with your gut. Whenever I go deep enough to do a head gasket, if I have any doubts about the radiator I'll take it...
    timsrv 05-29-2023, 04:32 AM Go to last post
    BelueJacques
    Flushed both heater cores both ways and they looked great. Pulled top radiator hose and what I can see (not much) does look completely clean. I’ve got a small amount of corrosion on the outside of...
    BelueJacques 05-28-2023, 03:00 PM Go to last post
    TimeTraveler
    Clogged Heater Core - Which (2) Lines Should Be Disconnected To Flush?
    I made the mistake of using Bar Leaks Head Gasket Fix and clogged the radiator and heater core. Going to try and flush the heater core and radiator.
    Does anyone know which two heater core...
    TimeTraveler 05-28-2023, 01:42 PM Go to last post
    alexpski
    Re:
    alexpski 05-27-2023, 04:27 PM Go to last post
    alexpski
    Removed
    Removed
    alexpski 05-27-2023, 04:20 PM Go to last post
    Make a Donation
  • Contact Us
  • ToyotaVanTech
  • Archive
  • Top
Powered by vBulletin® Version 4.2.5
Copyright © 2023 vBulletin Solutions Inc. All rights reserved.
2010 - ToyVan Support Group LLC
