Flushed both heater cores both ways and they looked great. Pulled top radiator hose and what I can see (not much) does look completely clean. I’ve got a small amount of corrosion on the outside of...
BelueJacques 05-28-2023, 03:00 PMI made the mistake of using Bar Leaks Head Gasket Fix and clogged the radiator and heater core. Going to try and flush the heater core and radiator.
Does anyone know which two heater core...
Re: diagnosing a headgasket failure
If you got another fan I'd probably try that 1st. If your funds are limited then go with your gut. Whenever I go deep enough to do a head gasket, if I have any doubts about the radiator I'll take it...
timsrv 05-29-2023, 04:32 AM
