If the starter is shorted internally, it would show as having continuity between the positive connection and the housing, same for the solenoid.
If not shorted, I would remove it and bench test it,...
the remote start was basically just looped between original starter/ ignition wire. as in it connected to small black wire to starter i referred to, ran through engine compartment to push button then...
Hikersteve74 03-21-2023, 09:41 AMAs I am working from memory and also suffer from CRS, take everything with a grain of salt
I dont believe I have ever met a starter that had anything other than 12v from battery positive on the...
No idea on "under chamber" if I were the guessing sort, I might head to the intake plenum, to the bundle of wires that connect to ground there.
My manual seems indicates that "b" (located on wiper...
Re: The WHAT-IS-THIS-PART and WHAT-IS-THE-PART-NUMBER Thread for Previas
Does anyone know the part number or part description for the gasket that goes between the head and the oil return pipe. This is the pipe that drains the valve cover area back to the oil pan located...
samstrader 03-21-2023, 03:17 PM
