    Jan-Willem
    Re: Multiple Warning Lights; Not Alternator?
    This is generic info, not van specific, so someone please correct me if I am wrong.
    The sense wire does indeed go directly to the battery, so the voltage should equal the battery voltage, always,...
    Jan-Willem 04-18-2024, 04:59 AM Go to last post
    Youngan
    Thanks; that did give me somewhere to start. Unfortunately, it didnÂ’t turn up a cause, but I did get some more data.
    I removed that short harness and tested continuity between the ends of each...
    Youngan 04-17-2024, 08:03 PM Go to last post
    MarkH
    Re: 84 Van dies just after starting
    This hose circled in red is the hard-to-see one that was disconnected in my van. It comes right off the intake manifold and is a large-diameter hose so if it is disconnected, it is a massive vacuum...
    MarkH 04-17-2024, 12:22 PM Go to last post
    MarkH
    Re: 84 Van starts then dies in seconds.
    Oh, and by the way, this issue didn't generate any diagnostic codes on my '85 1st gen van.
    MarkH 04-17-2024, 12:11 PM Go to last post
    MarkH
    I don't know if you ever solved your issue, but yesterday, I had the same issue. I had some vacuum leaks in the intake manifold and some sheared-off exhaust studs so I figured I'd remove the...
    MarkH 04-17-2024, 12:09 PM Go to last post
