ToyotaVanTech Forums - Powered by vBulletin
  • Register
  • Help
  • What's New?
  • Articles
    • TVT Vanwagon Owner's Manual
    • TVT Previa Owner's Manual
    • Tim's Tech Tips
  • Forum
  • Blogs
  • Advanced Search
  • Library
  • Home
  • Previa Historical Information
  • OEM Previa Dealer Literature (links)
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
  • Section Widget
    • Van Technical Information
      • TVT Van Service Manual
        • Maintenance
        • Engine Mechanical
        • Emission Control Systems
        • EFI System
        • Cooling System
        • Lubrication System
        • Ignition System
        • Starting System
        • Charging System
        • Clutch
        • Manual Transmission
        • Automatic Transmission
        • Transfer
        • Propeller Shaft
        • Front Axle and Suspension
        • Rear Axle and Suspension
        • Brake System
        • Steering
        • Body — Electrical System
        • Body
        • Air Conditioning System
        • Service Specifications
        • Standard Bolt Torque Specs
        • Electrical Wiring
      • Tech and Performance Mods (Vanwagon)
      • Custom Van Projects
      • TVT Previa Service Manual
      • Tech and Performance Mods (Previa)
      • Custom Previa Projects
    • Van Parts
      • Vanwagon Collision Catalog
      • OEM Van Part Numbers and Availability
      • Aftermarket Part Sources — Vanwagon
      • Parts Interchangability for Vans
      • Van-compatible Accessories
    • Previa Parts
      • Previa Collision Catalog
      • OEM Previa Part Numbers and Availability
      • Aftermarket Part Sources — Previa
      • Parts Interchangability for Previas
      • Previa-compatible Accessories
    • Van Historical Information
      • OEM Van Dealer Literature (links)
      • Vanwagon — external information links
      • Vanwagon articles and videos
        • TVT member articles — Vanwagon history
        • Vanwagon articles and press releases
        • Videos — Vanwagon commercials
        • Videos — Vanwagon, other
      • Previa — external information links
      • Previa articles and videos
        • TVT member articles — Previa history
        • Previa articles and press releases
        • Videos — Previa commercials
        • Videos — Previa, other
    • Tim's Tech Tips
  • Categories Widget (Show All)
    Scans of original Previa brochures
    llamavan
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Scans of Previa dealer brochures and literature can be accessed HERE ...
    Read More Read More
    Andywear
    Re: Lower Control Arm Bushings
    grinder with a 4" abrasive blade, 1/16" can be pretty precise.
    Andywear 05-20-2022, 08:34 AM Go to last post
    I'm not saying this is the right way, but I always remove the nuts and cam washers from the back side, then use a cutting torch on the heads and the threads that extend beyond the cross member. Then...
    timsrv 05-20-2022, 12:32 AM Go to last post
    89MasterAce
    Alrighty, I got new cam bolts, I got new bushings, I got new ball joints, but I've also got some very seized old cam bolts on the lower control arms.
    I think I'll have to sawzall the old ones...
    89MasterAce 05-19-2022, 09:28 PM Go to last post
    reddyfreddy151
    Any idea why the speedometer cable needle keeps going back inside the cable?
    I have an 1989 Toyota Van and installed a new speedometer cable but the needle on the inside of the cable keeps going in preventing contact with the gauge.
    reddyfreddy151 05-19-2022, 08:00 PM Go to last post
    Andywear
    Re: '93 LiteAce lift 4x4
    Instead of loading all the pictures thru the site I loaded them to a youtube vid. was much faster... maybe
    https://youtu.be/sOYBhwYfGHA
    I am still trying to figure out what steering...
    Andywear 05-18-2022, 10:56 AM Go to last post
    Make a Donation
  • Contact Us
  • ToyotaVanTech
  • Archive
  • Top
Powered by vBulletin® Version 4.2.5
Copyright © 2022 vBulletin Solutions Inc. All rights reserved.
2010 - ToyVan Support Group LLC
