ToyotaVanTech Forums - Powered by vBulletin
  • Register
  • Help
  • What's New?
  • Articles
    • TVT Vanwagon Owner's Manual
    • TVT Previa Owner's Manual
    • Tim's Tech Tips
  • Forum
  • Blogs
  • Advanced Search
  • Library
  • Home
  • Previa Historical Information
  • Previa — external information links
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
  • Section Widget
    • Van Technical Information
      • TVT Van Service Manual
        • Maintenance
        • Engine Mechanical
        • Emission Control Systems
        • EFI System
        • Cooling System
        • Lubrication System
        • Ignition System
        • Starting System
        • Charging System
        • Clutch
        • Manual Transmission
        • Automatic Transmission
        • Transfer
        • Propeller Shaft
        • Front Axle and Suspension
        • Rear Axle and Suspension
        • Brake System
        • Steering
        • Body — Electrical System
        • Body
        • Air Conditioning System
        • Service Specifications
        • Standard Bolt Torque Specs
        • Electrical Wiring
      • Tech and Performance Mods (Vanwagon)
      • Custom Van Projects
      • TVT Previa Service Manual
      • Tech and Performance Mods (Previa)
      • Custom Previa Projects
    • Van Parts
      • Vanwagon Collision Catalog
      • OEM Van Part Numbers and Availability
      • Aftermarket Part Sources — Vanwagon
      • Parts Interchangability for Vans
      • Van-compatible Accessories
    • Previa Parts
      • Previa Collision Catalog
      • OEM Previa Part Numbers and Availability
      • Aftermarket Part Sources — Previa
      • Parts Interchangability for Previas
      • Previa-compatible Accessories
    • Van Historical Information
      • OEM Van Dealer Literature (links)
      • Vanwagon — external information links
      • Vanwagon articles and videos
        • TVT member articles — Vanwagon history
        • Vanwagon articles and press releases
        • Videos — Vanwagon commercials
        • Videos — Vanwagon, other
      • OEM Previa Dealer Literature (links)
      • Previa articles and videos
        • TVT member articles — Previa history
        • Previa articles and press releases
        • Videos — Previa commercials
        • Videos — Previa, other
    • Tim's Tech Tips
  • Categories Widget (Show All)
    Previa specifications
    llamavan
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Previa specs from US dealer literature available HERE. ...
    Read More Read More
    Previa TV Ads
    llamavan
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    View original Previa TV ads HERE. ...
    Read More Read More
    VanCo
    Re: 1987 2wd automatic transmission in SLC for free
    FREE!
    I need it gone, but don't want to scrap it.
    VanCo 05-27-2022, 03:13 PM Go to last post
    Rustle
    Re: EGR Delete/Blocking Plate for 3C-T
    www.VanLifeNorthwest.com sells a kit.
    Here's the link.
    https://www.vanlifenorthwest.com/products/hiace-kzh106-kzh100-egr-block-off-plate-kit-30-1kz-te-engine
    Rustle 05-26-2022, 06:39 PM Go to last post
    Rustle
    Re: Thoughts on 3.0 1kz?
    Did you get it? I just got a 1996 with an 1KZ-TE motor.
    Rustle 05-26-2022, 06:37 PM Go to last post
    jannifiddle
    Re: Seat Belt malfunction
    Any advice on where to find aftermarket seatbelts for the front? I don't see anything on rockauto.
    thanks!
    jannifiddle 05-25-2022, 01:27 AM Go to last post
    89van
    Re: Broken steering shaft
    Yeouch! That's a bummer, wonder how that was broken. I believe that is called the Steering Bevel Gear Assembly, part numbers depend if you do or don't have power steering; someone else should be able...
    89van 05-24-2022, 09:46 PM Go to last post
    Make a Donation
  • Contact Us
  • ToyotaVanTech
  • Archive
  • Top
Powered by vBulletin® Version 4.2.5
Copyright © 2022 vBulletin Solutions Inc. All rights reserved.
2010 - ToyVan Support Group LLC
