    mosshopper
    Re: TPS Feeler Gauge Test-0.57mm???
    :dizzy:
    This was answered on page 3 of Cleaning the Throttle Body!! I tell you I read it many times.
    Apologies for my slop.:doh:
    I'll delete these messages if possible.
    mosshopper 02-17-2025, 12:55 PM Go to last post
    Jan-Willem
    Re: Ignition... completely lost
    I see you inspected the fuses, but did you check if there is power on them? I would start with the 7.5A IGN fuse. it should be powered if your key is turned to ignition. If it isn't check if power...
    Jan-Willem 02-17-2025, 07:40 AM Go to last post
    LeonDaneko
    a couple of days ago, I was driving along and suddenly there was no throttle response... but only for a second or two, all the lights, accessories, everything else was fine. then the power came back...
    LeonDaneko 02-16-2025, 09:49 PM Go to last post
    mosshopper
    I've successfully set a Throttle Position Sensor on an '86 2wd in the past following Tim's very excellent video and using forum advice...And a feeler gauge of .028 inches/0.70mm.
    Now doing the...
    mosshopper 02-16-2025, 08:35 PM Go to last post
    tbkilb01
    Re: Coolant In Cylinder
    mine popped and I saw smoke...checked water level and drove home. I relaced gasket in backyard. inspected pretty close and even valves held tightly against liqiuds. removed engine mounts and fished...
    tbkilb01 02-16-2025, 09:53 AM Go to last post
