• Diagnostic Codes for Toyota Vanwagons, all years
    Toyota Vanwagon Diagnostic Codes
    • To learn how to check your van for stored trouble codes, click here
    • For all vans, a steady blinking light (single blink) is your verification that the diagnostic system is functioning and has no stored codes.
    • For an example of how the "check engine" light behaves when a van is throwing two codes, click here.
    • To clear codes from the ECU’s memory after a repair, remove the EFI fuse (click here to locate) with the ignition switch off OR disconnect the battery. Toyota states “30 seconds or longer depending on the ambient temperature,” for the 3Y vans, but only “10 seconds or longer depending on the ambient temperature” for the 4Y vans. Lower temperatures require longer disconnect times.
    • To verify that a trouble area has been successfully repaired, you will need to clear the codes (see above) and run the engine (and possibly road test the van, depending on the exact malfunction) before checking for codes again.
    • For all problems and codes, it is possible (although highly uncommon) for an internal ECU malfunction to be the source of the trouble code. Consider substituting a known working ECU that is compatible with your van if you are unable to locate the problem; it is also possible to test the ECU itself with the aid of the Factory Service Manual and/or Electrical Wiring Diagram manual specific to your van’s model year.
    All ECUs have the part number on the case; use the part numbers below to assess possible compatibility. Part numbers were generated by a third-party source (ToyoDIY.com) and are not guaranteed to be 100% accurate by either ToyoDIY or by ToyotaVanTech.com.
    1984 and 1985 vans
    84 - 85 Diagnostic Codes.pdf
    one ECU — 89561-28010
    1986 and 1987 vans
    86 - 87 Diagnostic Codes.pdf
    multiple ECUs:
    89661-28040 — 2WD 5-speed
    89661-28060 — 2WD A/T
    89661-28080 — 2WD or 4WD, any transmission
    89661-28090 — 2WD or 4WD, any transmission, California vans ONLY
    1988 and 1989 vans
    88 - 89 Diagnostic Codes.pdf
    multiple ECUs:
    89661-28040 — 2WD 5-speed, up to and including 3/88
    89661-28060 — 2WD A/T, up to and including 3/88
    89661-28080 — 2WD or 4WD, any transmission, up to and including 3/88
    89661-28090 — 2WD or 4WD, any transmission, California vans ONLY, up to and including 3/88
    89661-28081 — 2WD or 4WD, any transmission, made during or after 4/88
    89661-28091 — 2WD or 4WD, any transmission, California vans ONLY, made during or after 4/88
    89van
    Re: Sliding door handle / exterior mechanism
    Got the panel off and my side door opening again! :dance1: For anyone else curious how to remove the door panel, it goes a little something like this:
    Get some needlenose pliers, a philips head...
    89van 06-09-2023, 03:21 PM Go to last post
    alexpski
    Re: Help ID this part
    Thank you! I had someone tell me that but I needed to confirm. Appreciate your tesponse!!
    alexpski 06-09-2023, 10:01 AM Go to last post
    Jan-Willem
    I think it is the temperature sensor that disables the overdrive of the automatic gearbox when the engine is cool.
    12140
    Jan-Willem 06-09-2023, 06:56 AM Go to last post
    alexpski
    Help ID this part
    Can anyone tell me that the green sensor is below the temp sensor?
    Temp sensor is circled in this pic.
    alexpski 06-08-2023, 08:18 PM Go to last post
    Jan-Willem
    Re: Head Gasket Repair - Parts Checklist
    Oh really? Are mine not original? I honestly have no idea, but on mine the connector is the bosch ev1 connector. I do not have access to another van, to see if it has different injectors/connectors.
    Jan-Willem 06-08-2023, 07:48 AM Go to last post
