Hello di you find the issue cause I have the same ? tks
Fabe21 04-18-2024, 07:33 AMThis is generic info, not van specific, so someone please correct me if I am wrong.
The sense wire does indeed go directly to the battery, so the voltage should equal the battery voltage, always,...
Thanks; that did give me somewhere to start. Unfortunately, it didnΒt turn up a cause, but I did get some more data.
I removed that short harness and tested continuity between the ends of each...
This hose circled in red is the hard-to-see one that was disconnected in my van. It comes right off the intake manifold and is a large-diameter hose so if it is disconnected, it is a massive vacuum...
MarkH 04-17-2024, 12:22 PMOh, and by the way, this issue didn't generate any diagnostic codes on my '85 1st gen van.
MarkH 04-17-2024, 12:11 PM
