Register
Help
Remember Me?
What's New?
Articles
TVT Vanwagon Owner's Manual
TVT Previa Owner's Manual
Tim's Tech Tips
Forum
Blogs
Advanced Search
Home
Tim's Tech Tips
If this is your first visit, be sure to check out the
FAQ
by clicking the link above. You may have to
register
before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
'); loadVbCss(yuipath + '/treeview/assets/skins/sam/treeview.css'); //-->
Section Widget
Features of the ToyotaVanTech site
Van Technical Information
TVT Van Service Manual
Maintenance
Engine Mechanical
Emission Control Systems
EFI System
Cooling System
Lubrication System
Ignition System
Starting System
Charging System
Clutch
Manual Transmission
Automatic Transmission
Transfer
Propeller Shaft
Front Axle and Suspension
Rear Axle and Suspension
Brake System
Steering
Body — Electrical System
Body
Air Conditioning System
Service Specifications
Standard Bolt Torque Specs
Electrical Wiring
Tech and Performance Mods (Vanwagon)
Custom Van Projects
Previa Technical Information
TVT Previa Service Manual
Tech and Performance Mods (Previa)
Custom Previa Projects
Van Parts
Vanwagon Collision Catalog
OEM Van Part Numbers and Availability
Aftermarket Part Sources — Vanwagon
Parts Interchangability for Vans
Van-compatible Accessories
Previa Parts
Previa Collision Catalog
OEM Previa Part Numbers and Availability
Aftermarket Part Sources — Previa
Parts Interchangability for Previas
Previa-compatible Accessories
Van Historical Information
OEM Van Dealer Literature (links)
Vanwagon — external information links
Vanwagon articles and videos
TVT member articles — Vanwagon history
Vanwagon articles and press releases
Videos — Vanwagon commercials
Videos — Vanwagon, other
Previa Historical Information
OEM Previa Dealer Literature (links)
Previa — external information links
Previa articles and videos
TVT member articles — Previa history
Previa articles and press releases
Videos — Previa commercials
Videos — Previa, other
Tim's Tech Tips
Maintenance
Engine Mechanical
EFI System
Cooling System
Lubrication System
Ignition System
Starting System
Charging System
Clutch
Manual Transmission
Transfer
Propeller Shaft
Brake System
Steering
Body
Electrical Wiring
Custom Van Projects
Van Parts
Previa Parts
Tim's Tech Tips
Categories Widget (Show All)
Tim's Tech Tips
Cleaning the Throttle Body
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
The throttle body is a pretty simple component but after years of service the internal passages can become clogged/dirty ...
Read More
Starter clicks but won't crank!
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
There are several possibilities here, but before doing anything, inspect your battery cables and terminal ends to make sure ...
Read More
2 Comments
Fusible links
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
The FL 1.25B fusible link is a common problem area on these vans. To start with it's in an odd place. It's tucked up in ...
Read More
2 Comments
Testing fuel system / replacing fuel pressure regulator
View Profile
View Forum Posts
View Blog Entries
View Articles
Published on 01-08-2012 02:04 PM
Categories:
Article
For testing the fuel system I'm using Harbor Freight's cheap
Injector Pump Test Kit
. The van I'm testing is an 89 2wd cargo ...
Read More
Tires, tires, tires!
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
A common question is "what size & type tires will work best for me?". Well, lets start out with recommended ...
Read More
5 Comments
Heat soak / Hot soak
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
There is a sequence of events and certain conditions that lead up to hot soak. It's hard to accurately duplicate these conditions ...
Read More
6 Comments
Other parts to replace while replacing Head Gasket
View Profile
View Forum Posts
View Blog Entries
View Articles
Categories:
Article
Please read
Diagnosing Head Gasket Failure
before getting started (if it ain't broke, then don't fix it). Okay, so you've ...
Read More
How to replace your ball joints in about 2 hrs (2wd)
View Profile
View Forum Posts
View Blog Entries
View Articles
Published on 10-08-2010 02:30 AM
Have you ever got an estimate from a shop to replace ball joints? If so, then you know this isn't a cheap job. What they ...
Read More
Drive shafts and u-joints
View Profile
View Forum Posts
View Blog Entries
View Articles
Published on 10-02-2010 01:27 AM
Categories:
Article
If you have an 84 or an 85 van, then you are in good shape. Toyota made your u-joints replaceable. This means any reputable ...
Read More
A few tricks for removing broken exhaust studs
View Profile
View Forum Posts
View Blog Entries
View Articles
Published on 09-16-2010 04:56 AM
Categories:
Article
Well, I finally decided to do something about that annoying exhaust leak, so I tore down the van and found I have a cracked ...
Read More
