Re: 4 runner torsion bar MOD
Very impressive. Thanks for sharing. Glad you got the results you were looking for. I'm curious as to the logic behind this. I know the stock 4wd van torsions are 22 mm diameter. What is the diameter of the 4Runner bars? I drive overloaded 2wd cargo vans (19.8 mm dia bars) & might be interested in such an upgrade. Tim
4runner t bars are 25mm diameter.
There is only 4" of travel in the front suspension. Maybe 5 if you trim the bump stops.
I setup the torsion bars 3" compression travel. 1"' droop.
Or 18.5" hub to fender.
coronan, this is awesome! I'm wanting to get the needed lift in front without the cranked torsions. I did the aerostar springs/tacoma shocks in rear and its working really great so far. however the front..... it rebounds like a trampoline when off-roading. additional travel would also be super nice to have. i don't have any fab/welding tools or skill however.
Is this something i could have a shop (reasonably) do? Is there any other lift methods for the front? My understanding with your mod is that its simply allowing you to have the additional 1-2" of lift without all the preload due to the thicker diameter torsions.
Thats correct. I wanted better ride quality at the same ride height of cranked torsion bars.
It still bounces if i drive the van too hard. But its much improved. Speed bumps dont buck me out of my seat any more.
I didnt hear you say that you replaced the front shocks.
I really believe bounce should be controlled by shocks.
I would like to see someone fit adjustable rancho shocks.
Maybe dual shocks.
We gotta think out of the box with These vans as there is no aftermarket support.
I haven't actually replaced the front shocks, but its on the list. The PO claimed he replaced them but they don't control bounce well at all. I just assume the cranked torsions were to blame for that.
Dual shocks would be awesome! Do you have a thread for your coiler project? I'd be interested to see that.
I have zero equipment or experience with fabrication of this level so I have to rely on the creativity of others in this forum :LOL2:
I'm totally going to do this mod. The OG front torsions were designed around small framed Japanese families I suppose because with 2 slightly overweight Americans (me, lol) in the front seats it nearly bottoms out. Now to get dimensions for everything and start ordering parts.
please keep this thread updated with your progress. I think this would be a very common mod if there was a good write up on it. I replaced the shocks with the Bilsteins (Dodge Durango) and have had them in for a year or two and they help a lot but I think the better torsion bars along with those would really tame the bounce down significantly while still maintaining the lift.
Im just now finally getting around to this project. I think im going to attempt to get the dimensions measured up, 3D print some drop-in test-fit parts for the conversion, then have them machined from billet steel. If there’s anyone who has any dimensional data I’d appreciate it. Otherwise I’ll try and measure everything.
