Standard to LE (add tach) and LE to standard cluster swaps
So I've come across an le van cluster with a tac... My cargo has no tac and was planning on installing an aftermarket gauge. But I'd think it be cleaner to install an le cluster with the tac. Before I tear into this ADDED project I'd like to know if it's even possible to wire this up. Any help is appreciated!
Re: Intrument cluster swap
I went the other way, from a 87 tach cluster into my 84 DX. I changed pins to correct positions, had to find rpm wire going to computer, splice and run a new wire for tach signal (found the wire going to the computer under drivers footrest near left footwell), finally change oil pressure warning light sensor to different one that outputs for the pressure gauge. There may have been a different type connection that need to be spliced for the pressure sensor, can't remember. Good luck.
