Aftermarket Tie Rod Ends and Idler Arm
Spouse's 1985 DLX has been diagnosed as needing a new Idler Arm and Tie Rod Ends. I don't do steering (yet), but he got a second opinion (with no monetary interest involved) who concurred.
Idler Arm is NLA from Toyota and I'm not keen to put one on from a parts van of dubious history, even the rust-free ones. Tie Rod Ends are still available but $70+ each. I did find aftermarket options for both from Rock Auto. My question is whether anyone has experience with these brands (good or bad) specifically in these applications before I order.
Idler Arm options — Moog, Mevotech, Beck-Arnley, Raybestos, ACDelco
Tie Rod End options — Beck-Arnley, Mevotech, Raybestos, ACDelco
Thanks for any input!
Re: Aftermarket Tie Rod Ends and Idler Arm
I have not purchased these specific parts before, but have purchased Moog suspension parts for other applications and felt they were of good quality. I've had mixed luck with Beck Arnley depending on the type of part. I used Beck Arnley ball joints before and was not impressed with durability (lower right failed miserably after only a couple years...........the original Toyota part was in better shape after 25 years of service). Could have been a fluke, but this was my 1st (and last) time using Beck Arnley ball joints.
Not sure about Mevotech, but I've had pretty good luck with AC Delco and Raybestos parts.
I'd trust all of them, but never heard of "movotech?" Find out where they are made, if possible...(I found lower ball joints from Japan with the boxes covered in dust at a local auto store!) Almost any decent outer tie rod should last a long time...buy a "pickle fork" and install them yourself--pretty straightforeward. (then get alignment) --- good luck
I went with OEM outer tie rod and AM inner by Import direct on my 4x4 van but I think I'll be doing AM for the driver side using ACDELCO, it'll be half the price and hopefully not half the quality.:?:
Gwen let us know what you go with please thx!
llamavan
Have used Beck Arnley idler narm. Works well
Have used tie rod ends from Beck Arnley, TRW, Moog, and Raybestos. The tie rod sleeves should also be purchased, but you may have to transfer the clip.
They are inexpensive and easy to replace. I bought them all from Rock Auto over the years. Surprisingly the Moog lasted the least.
John
Hi John,
You may not still be around but I just wanted to comment on Moog lasting the least for your tie rod ends. I replaced my first set of inner tie rod ends on my van after 380000 miles. I used Moog because I thought they would last. After 20000 miles the Moog are already toast. That's surprising to me.
I have been having better luck on various vehicles by using Rock Auto's least expensive parts lately {quality name-parts that are on closeout} ... also heard a lot of very poor moog stories in the last few years. However, the front upper control arms that were a success were a step or two up on their price listings (AC Delco).
Thanks for your reply Tan Van,
I'm not going to buy Moog parts anymore. I always thought they were good.
I have been buying closeout items from Rock Auto just like you just to have around since some of the closeout items are so cheap. I got a set of ignition wires a couple of years ago for $2.00 and they were the highest quality wires I have ever bought for any car. I also just bought a closeout starter with no core charge for $49.00.
I will get a warranty cash refund on the Moog inner tie rod ends I bought since Rock Auto doesn't carry them anymore and can't replace them. They had a lifetime warranty. I'm buying the Delphi Technology tie rods this time and hope I have good luck with them.
It is so frustrating to me to buy parts that are junk. I don't like to have to do a job twice or three times because I can't find good parts and since OEM Genuine Toyota parts are mostly not available now, it is getting real hard to find good parts.
I bought most of my tie rod needs at Rock Auto thanks to this thread... thank you all btw. I'm still struggling to replace Toyota part # 45470-29065(driver's side tie rod assembly) .
I can't seem to find an aftermarket replacement for it and Rock Auto seems to be sold out of anything to replace it. I have seen that Toyota part # 45460-29256 was the oem replacement but that doesn't seem right. And besides, I can't find an aftermarket replacement for that either.
Any other resources to find parts that anyone can recommend?
Much appreciated.
hello jojo.
I did a quick google search and found the left tie rod end sub assembly. Would this part help you? I don't know much about your van, I have a Previa, So forgive me if this is a stupid post.
1984 Toyota Van Tie Rod End | Low Price at ToyotaPartsDeal
https://www.toyotavantech.com/forum/...AAAElFTkSuQmCC
This was definitely where I started. Trying to replace 45470-29065 or 45460-29256 has been a challenge. Both OEM are discontinued and I can't find a straight answer as to whether the 2 part numbers are actually interchangeable. The part is cheap enough that I'll probably buy what I can find and see...
