Question: How to uninstall driver's seat
I'm sorry if this has already been posted, but in my search I found nothing. Does anyone know how to take out the driver's side seat? I have taken out the passenger seat many times, but after unscrewing many bolts, it is stuck in there good.
The reason I am trying to do this is because my chair isn't sliding and I'm dangerously too far away from the pedals. -- If anyone knows a simpler solution to this, I will gladly take it! :yes:
Re: Question: How to uninstall driver's seat
Had this issue w/ my most recent van. Used a combo of WD40 (for possible rust/moisture) and standard turbine oil on the seat rails. Lot's of both. Let it sit over night and could feel it start to budge the next day. Took some muscle, but it came unstuck. Also, there's probably bolts you can't get to because your seat doesn't move, which is why it's not coming out. Good luck!
I've run into this twice on my 89. I know your hood latch is different but I'm guessing the seat is similar. The seat is attached by 4 bolts, two at the front and two at the back, all accessed from the top. If your seat won't go forward all the way you may not be able to see the ones in the back, so you might have a hard time getting it off.
The most recent time it was caused by a loose bolt falling down under the seat and landing on the rail. Remove the front bolts and take a look under there.
The other time I had a problem with it not moving properly was because the seat has a weird mechanism for limiting forward/back motion. There are tabs that stick out the right side of the seat and fit into a groove attached to the van. If it has come out of the groove it might be hitting something else and causing the problem. Hopefully with the front bolts removed you'll be able to wiggle them back into place.
Good luck!
Thanks for the help everyone! After some lube and muscle and removing the back of the back of the seat, it moves!
Re: Drivers Seat Removal?
Figured it out. It is just removing the four bolts on the seat track. Then you have to tilt the seat to get the seat belt latch out of it's track. My issue was the small pencil that was in the seat belt latch track... tons of stuff under there.
