Ecu location and idle rpm box smoking
I'm new to this website but excited to be on here. I am confident I blew the computer ecu/pcm in my 1984 toyota van. I smelled smoke and my rpm box is making all my relays go haywire on off constantly if I tap it or wiggle it its worse also i see blown capacitors and resistars I know the ecu is probably the same but I need help pinpointing where it hides I've got the dash all out and don't see it
thanks a ton,
Dustin
Re: Ecu location and idle rpm box smoking
The ecu is mounted down low in the left(driver side) "B" pillar behind the seat belt retractor.
Thankyou a ton I would have never looked there in a million years
How does one go about removing the plastic panels to get to the ECU?:dizzy: I don't want to break these panels trying to pry them off.
Hers a inside picture of the left side panel that should help-
That should help. Thanks so much. Now I know which way to slide it off of those plastic fasteners, at least.
