Oil leaks from belly part of the van.. pls help..
Hi guys just owned a 1991 previa se model, please help me to resolved some oil leaks on my van, to begin with i noticed that my windshield washer at frint dont work, so when i check i noticed that its near on the oil reservoir and windshield reservoir also, i disconnect hoses and motor of windshield washer and after i cleaned the hoses and pour water the windshield washer is working, vut when i removed the previa from my garage i notice an oil spill on the floor please help me what to do?? More power toyotavantech..
Re: Oil leaks from belly part of the van.. pls help..
Oil on floor? Look up to see where it came from. If you accidentally disconnected a line from your oil reservoir while working on your windshield fluid issue, it would likely leak oil.
If your windshield is now oily and there's wiper fluid in your crankcase, you've got more serious problems.
I bought a car once that had clean motor oil in the engine coolant overflow tank. S#%t happens.
