Re: Charging System Problem
Did you check the fuseable link by the battery?
Yeah. The charging, engine & IG fuses also checked. They are fine. The tech who installed security system, has installed a separate wire from Alt. light contact to dashboard batt. indicator light ( negative side) , disconnecting the original wire. Will be replacing that with a new wire, today, if time permits.
When IG is off (key in off position), IG wire which turns alt. on, is getting grounded. When a voltmeter is connected between + terminal of batt. & the Alt. end of IG wire , it has a reading of ~12v. Is this normal?
When IG is off, sense wire connector on Alt. is sinking ~10v. Is this normal? Shouldn't it be off?
