'94 Previa - Low Beam Headlights Not Working
Turned on my headlights the other night and both low beams are out? High beams and yellow parking lights work fine. I checked the two head light fuses in the dash panel and they are good - are there others I should look at?
I haven't changed the bulbs yet because it seems strange that both would go out at the same time.
Has anyone run into this issue :cnfsd:
Thank in advance for any ideas...
Re: '94 Previa - Low Beam Headlights Not Working
Had both beams burn out on a ford one year within 2 days of each other. Your right tho, what are the odds?
There's a relay in the negative side of the circuit. Check that.
