95 Previa LE Supercharged Front Blower Mystery
Hi, first ever post.
Need to solve front blower issue. After eventually loosing all front heater fan speeds, R&R motor brushes (worn down to dust but commutator OK) and resistor. This got fan working but intermittently. R&R fan speed switch. Worked first try but then not, then OK. AC goes on when depressed. Is ignition switch possible problem?
981VanMan
Re: 95 Previa LE Supercharged Front Blower Mystery
981VanMan
981VanMan
:dance2:Mystery no longer. Fan works. Switch replacement was the cure. 981VanMan.
