Re: Preventing HG Failure..
Replace the coolant and the thermostat right away. Previa thermostats can fail closed (happened to my very neglected one). Toyota thermostats are actually cheap and replacing it is one of the simpler things on this vehicle. Keep a close watch on temp, leaks, etc for the first few hundred miles you have it, and unless you have reason to suspect something I'd leave everything else be.
Did you get the van?
Jonny
Yeah I did get the van. I will do a post about it here in a sec. I bought a Aisin 180F thermostat...well ordered...I did a huge order to do a major tune up...I bought a few Toyato items but needing so much at one time, I was trying to save a few bucks if I could..
Get all the old coolant out by draining the radiator
And the engine by unscrewing the 10 mm bolt that's by the oil filter and is vertically oriented. Replace the thermostat at same time since will get more coolant out when pulling the hose off the water pump outlet where the stat is, use a Toyota oem stat.
Pull the reservoir and clean all three small tube inlets as they will all be plugged. I usually refill with distilled water several times to get all old antifreeze out. Then refill with toyota red plus distilled water to 50/50. I use pb blaster on the 2 thermostat nuts the day before as they will be rusted. Make sure rad cap is good or just replace it.
