Toyota Van Lubricant and Fluid Specifications
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SL
Maximum Performance Signature Series 10W-30 Synthetic MotorOil (ATMQT) Signature Series 10W-30 Synthetic Motor Oil (ATMQT)
Drain Interval Information
Performance Plus XL 10W-30 Synthetic Motor Oil (XLTQT) XL10W-30 Synthetic Motor Oil (XLTQT)
Performance OE 10W-30 Synthetic Motor Oil (OETQT) OE 10W-30Synthetic Motor Oil (OETQT)
Above 10F......15W-40, 20W-40, 20W-50
Above -9F......10W-30, 10W-40, 10W-50
Manual Transmission,G53 (4WD)......GL-5
AllTEMPS......75W-90, 80W-90
Severe Gear®75W-90 (SVGQT)
Severe Gear®75W-110 (SVTQT)
SAE 80W-90Synthetic Gear Lube (AGLQT)
Manual Transmission,G53 (RWD)......GL-5
Automatic Transmission,A45DF......AF3
SignatureSeries Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OEMulti-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,A45DL......AF3
Differential, Rear RWD......GL-5
Above 0 F......90
Differential, Front......GL-5
Above 0 F......90[1]
Differential, Rear 4WD......GL-5
Above 0 F......90
Below 0F......80W-90, 80W
Below 0F......80W-90, 80W [1]
Transfer Case,U/K TRC......GL-5
Transfer Case,U/K TRC......GL-4
ManualTransmission & Transaxle Gear Lube 75W-90 (MTGQT)
Fluids
BrakeFluid......HB
DOT 3 and 4Brake Fluid (BFLVCN) [2]
ClutchFluid......HB
Power SteeringFluid......AF3
OEMulti-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [3]
[1] Front differential is for 4WD models only.
[2] Hydraulic Brake Fluid, DOT 3
[3] DEXRON-III Automatic Transmission Fluid
FILTERS:
Oil Filter
Absolute Efficiency Oil Filter (EA15K51)
[1]
Oil Filter
MANN Oil Filter (W92017)
Oil Filter
WIX 51068 Oil Filter
[2]
Oil Filter
WIX 51034 Oil Filter
[3]
Air Filter
WIX 46146 Air Filter
Fuel Filter
WIX 33500 Fuel Filter
[4]
Transmission Filter
WIX 58946 Auto Tran Filter
[1] Replaces the Ea15k33, which will still work for thisvehicle
[2] Automatic (TransmissionControlType)
[3] with Manual Transmission
[4] Universal Style with Adjustable Cradles
CHASSIS LUBRICATION:
RWD
0 Fittings, 4Plugs..........LM
4WD
1 Fittings, 8Plugs..........LM
CAPACITIES:
Engine, with filter..........3.7 quarts [1]
Cooling System, With RR HEAT & 4WD InitialFill..........7.9 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Cooling System, With RR HEAT & RWD InitialFill..........9 quarts
Cooling System, Without RR HEAT & 4WD InitialFill..........7.4 quarts
Cooling System, Without RR HEAT & RWD InitialFill..........7.9 quarts
Automatic Transmission, A45DL Initial Fill..........2.5quarts
Automatic Transmission, A45DF Initial Fill..........2.5quarts
Automatic Transmission, Total Fill
4 speedA45DL..........6.9 quarts
4 speedA45DF..........6.9 quarts
Manual Transmission, G53 (RWD)..........4.9 pints
Manual Transmission, G53 (4WD)..........5.5 pints
Differential, Front..........2.7 pints [2]
Differential, RWD Rear..........3.2 pints
Differential, 4WD Rear..........4 pints
Transfer Case, U/K TRC..........2.5 pints
[1] After refill check oil level.
[2] Front differential is for 4WD models only.
Re: Toyota Van Lubricant and Fluid Specifications
Is there any reason the plugs on the ball joints should not be replaced with zerk fittings?
Don’t see why not! Make sure you use 90 degrees one and angle them for access with the gun even with the wheel on. I haven’t done that on my on mine but it’s on my list.
Just want to clarify one thing, because of a pretty valid question on Gear oil type for the trans. We have a g series trans in our vans (g 53). It does contain bras synchros, at least those not rebuilt will. GL5 is fine. The amount of sulfur (read trace amounts) won't harm your manual trans. The FSM says it's all good too.
Attachment 8382
Flecker
I'm going to be changing the oil on my rear differential - '86 RWD, Manual - Can anyone recommend a specific brand and number of gear oil that I can buy at one of the big auto parts stores in town? I see a lot of different info around on what diff oil to use.
Good day folks, apologies for the necro I guess but this seems suitable, so from my understanding either DEX III/DEX IV is suitable as it superseded it. Seems my van lost some ATF from sitting thanks to a leak on the transmission pan. Fluid is dark like motor oil so its probably well-due for a change I guess, although not sure when the last one was done and I really don't want to kill my transmission...
