Temperature Gauge Dash Bulb
I've been searching on how to replace the bulb for my temp gauge. i found this:
http://toyotavanpeople.com/forum/vie...hp?f=11&t=5426
but i'm not sure if i need to remove everything just to replace a bulb. Is there a way to replace it from behind the assembly or do i need to take everything apart? thanks
Ben
Re: Temperature Gauge Dash Bulb
I remember that thread. I'm glad to see it's still there (I had several like this that got wiped out). Yep, all the info you need is there in that thread. I should copy and paste over here before their next "mis-hap". Tim
PS: Due to the way the cover snaps on the temp control panel, you will need to disassemble......but it's really quite quick and easy. If it's the light in the cluster, then you need to pull the cluster too. Once removed, there's easy access to the bulb from the back of the cluster. Tim
Okay, here's a copy/paste of my posts from that thread (for safe keeping here). Enjoy :)>:
The original poster on that thread was asking about the lighting behind the temperature control panel.........here's my response:
Yes, there are 2 small incandescent bulbs that are wired from your heater fan switch assembly (Toyota Part # 90981-11014). These are the bulbs that illuminate this area. I'm guessing they are both burned out. They are not hard to change once you get some access, but in order to do that, you need to partially disassemble your dash. I snapped some pictures for you of an extra heater control I have so you can see how the control assembly comes apart. You will most likely need to remove the hinged change tray / compartment at the bottom center of your dash, the cigerette lighter assy, the ash tray, the radio & trim assembly, then pull the mounting screws for the heater control before you get enough access to pull the fascia off of it and get to the bulbs.
Using a small screw driver, pry out one of the hinges to the change tray, then open it and it will come off.
http://i8.photobucket.com/albums/a23...r/IMG_8600.jpg
Remove the ash tray.
http://i8.photobucket.com/albums/a23...r/IMG_8598.jpg
Pull the wires from the lighter assy, then remove the black plastic cover piece.
http://i8.photobucket.com/albums/a23...r/IMG_8597.jpg
A 90 deg scribe works well to release the plastic hooks.
http://i8.photobucket.com/albums/a23...r/IMG_8595.jpg
Push the metal part of the assy out from behind.
http://i8.photobucket.com/albums/a23...r/IMG_8592.jpg
Use your scribe to release the plastic hooks, then remove the white plastic part.
http://i8.photobucket.com/albums/a23...r/IMG_8591.jpg
http://i8.photobucket.com/albums/a23...r/IMG_8589.jpg
The plastic garnish will pull off now. Do not twist or change angles. Grab it firmly and pull straight toward you.
http://i8.photobucket.com/albums/a23...r/IMG_8587.jpg
Remove these 4 screws, then the drink tray and frame assy will come out. It's a tight fit, but play around trying different angles and it will come out when you find the right ones.
http://i8.photobucket.com/albums/a23...r/IMG_8585.jpg
Take out these 2 screws.
http://i8.photobucket.com/albums/a23...r/IMG_8584.jpg
Find the hidden latch, and remove the top center dash / fuse box cover.
http://i8.photobucket.com/albums/a23...r/IMG_8601.jpg
Remove these 2 screws.
http://i8.photobucket.com/albums/a23...r/IMG_8582.jpg
Remove the radio and fascia assembly.
http://i8.photobucket.com/albums/a23...r/IMG_8579.jpg
Once you have adequate access, pull the knobs off the control levers.
http://i8.photobucket.com/albums/a23...r/IMG_9241.jpg
The next 3 pics show the plastic catches that need to be undone to remove fascia.
http://i8.photobucket.com/albums/a23...r/IMG_9237.jpg
http://i8.photobucket.com/albums/a23...r/IMG_9238.jpg
http://i8.photobucket.com/albums/a23...r/IMG_9240.jpg
Here is the optical piece, it lifts right out once the fascia is removed.
http://i8.photobucket.com/albums/a23...r/IMG_9236.jpg
And here are the 2 bulbs. They pull straight out of the sockets (no twisting, just pull).
http://i8.photobucket.com/albums/a23...r/IMG_9235.jpg
There are also 2 general illumination bulbs in the gear selector indicator, one bulb for each gear shift position and one for "O/D OFF" light. With the exception of the radio, I replaced all of the general illumination bulbs in my dash with high intensity blue LEDs. Some were easy, but some were pretty darn difficult. LEDs run cool and last for a long time, but they will burn out if you try to run them on 12 volts. Because of this, each LED bulb must have a specific resistor wired in series with it to reduce voltage. Time and patience are required to isolate the circuits, cut, and install these resistors. Tim
Here is a disassembled view of the gear selector indicator. The 2 general illumination bulbs are the ones with the purple arrows. The "O/D OFF" light is the clear one on the far right, and the others are self explanatory.
http://i8.photobucket.com/albums/a23...r/IMG_9250.jpg
When I mentioned difficulty of installing LEDs, the gear selector indicator was one of those trouble spots. Perhaps the most difficult of all was the 2 little light bulbs in the heater control. Just swapping incandescent bulbs is already a pain, but in order to install LEDs with the resistors, the entire fan switch needed to be removed. Here are some pics of my modified fan switch (with LEDs and resistors) before it was re-installed.
http://i8.photobucket.com/albums/a23...r/IMG_8606.jpg
And here are some pics of the dash illumination after the project was completed.
http://i8.photobucket.com/albums/a23...r/IMG_9247.jpg
http://i8.photobucket.com/albums/a23...r/IMG_9242.jpg
http://i8.photobucket.com/albums/a23...r/IMG_9245.jpg
If you need to remove the cluster, it's not so hard once you get the radio and garnish assy out. There's only 2 screws holding the instrument hood on
http://i8.photobucket.com/albums/a23...r/IMG_8578.jpg
After the screws are out, there are still 5 fasteners, but they are the push-in / pull-out type. There are these 3 bumps on the hood
http://i8.photobucket.com/albums/a23...r/IMG_9292.jpg
and they go into these 3 holes in the dash panel
http://i8.photobucket.com/albums/a23...r/IMG_8571.jpg
The other 2 are here by the heater duct.
http://i8.photobucket.com/albums/a23...r/IMG_9291.jpg
All you need to do (after you pull the 2 screws) is grab a hold of the hood and yank. It should pop right out. Just be careful to pull straight so you don't tweak the heat duct section. Sometimes you need to carefully loosen this area with a knife as to avoid damage while yanking out.
http://i8.photobucket.com/albums/a23...r/IMG_8576.jpg
After you get the instrument hood off, all fasteners are pretty obvious and shouldn't be much of a problem to figure out. You will need to pull the cluster, flip it over, then you'll see the 2 screws that hold the shift indicator onto it. Have fun. Tim
thanks!! and do you you know the part number for the bulbs so i can have them ready when i take it all apart?
If you are talking about the general illumination for the cluster, these are a standard #161 bulb that can be found almost everywhere. The bulbs do not come with the tiny green "condoms", but you can usually peel these off of the old bulbs and re-use them.........:LOL2: .........Or, you can take this opportunity to upgrade to the LED bulbs like I used above. LEDs draw less power and run cooler. Tim
Hey there Tim, I would love to put blue l.e.d. lights . Could you tell me where you got them? :dance2:
I got the small bulbs & resistors at Fry's electronics. Here's a picture of them in the package:
http://i8.photobucket.com/albums/a23...ps3b17e3ab.jpg
The 168/194 bulbs (single bulb with blue base in above picture) I found on eBay. These ones already have the resistors built in, so all you have to do is pull out the old & put in the new. One thing to remember though, LED's are polarity sensitive, so you will need to test these before putting your dash back together. If any of them don't work, then pull them back out, rotate 180 deg, then put back in. I bought a bunch of these eBay about 5 years ago & still have a bunch left. I just checked and don't see the exact ones I got, but there are literally thousands on similar bulbs to choose from. Here's one of the listings I clicked on: http://www.ebay.com/itm/8000K-Blue-T...a80709&vxp=mtr
the blue light at the bottom seems big to me. would the fix in the back of the instrument panle? it looks more the size of a 194? i would rathe do a plug and play led light then start cutting wires
Several of the general purpose lights in the cluster are 194/168 bulbs...........that's what I use this bulb for. The 5mm ones in the package are used for the shift indicator & for the fan switch. Tim
gotcha. thank you Tim for clearing that up for me.
So I blew my dimmer switch bulbs when I wired my radio wrong. I fixed the radio issue (Thanks TVT, why I didn't check this with you first I will never know) but now I need new bulbs. I'm looking at these options but I'm worried that they might be too bright. Also what else uses the #161 bulb in a 1989 LE?
https://www.amazon.ca/gp/product/B01...7HQ2EF6B&psc=1
https://www.amazon.ca/YINTATECH-Wedg...07G8VXTZ0JWVHC
https://www.amazon.ca/Grandview-Repl...placement+blue
Good luck. The last batch of LED wedge bulbs I got off amazon were junk. They seem to vary so much from one purchase to another (can never get the same thing as before).............and sometimes that is a good thing. The ones in your 1st link appear to be too big, but the others may work okay. Tim
PS: for more "vanwagon specific" information, check here: http://www.toyotavantech.com/forum/s...s-Where-to-buy
Thanks again Tim, I believe the light in my shifter has also been burnt out in the same accident, is the a forum started for fixing such an issue? Do you know what size bulb I need to remedy the situation?
