Re: Drive shaft balancing
I too have used this method to balance shafts. It sucks there are guys out there that do shoddy repairs. I spent $300+ on a drive shaft one time and the welds looked like a high school kid did them. It was disappointing, but not much recourse except hoping for the best or finding another shop :no:. Tim
I know this problem too. I bought a 4runner new in 88 that had a driveshaft vibration problem right at 55mph. The dealer reversed the shaft and it changed the vibration to some other annoying spot (I can't remember which) but that speed too was a common one when driving. Eventually Toyota put a new shaft on. And now I find a hoseclamp, a washer and a piece of chalk was all that was needed?I'm not really clear on how to use the chalk from the description here but we may all be using this method soon as our drive shafts can't last firever and more and more of us are going to be heading down the 'rebuild' route.
When a drive-line is out-of-balance, at speed the heavy side will pull away from the center and the light side will pull toward the center. The chalk is simply a way to mark the heavy side. When you get the drive-line up to speed, carefully hold your chalk up, and only the heavy side will touch it. A well balanced shaft will make 360 deg contact with the chalk. Tim
