Question on Idler Pulley Adjuster Removal: 94 LiteAce 2C engine
Hello, Folks.
I tried to adjust the A/C belt today but I found out that the head of the adjuster bolt was missing. It seems it was snapped off during the last service. That mechanic didn't tell me so. I guess that's why the AC belt has not been tight enough in the first place. So I removed the drive belts (alternator-fan-crankshaft), PS pump belt, and the A/C belt. And I removed the nut at the center of the idle pulley and removed a couple of washers (a big one and a small brass one). The idler pulley is now wiggling up and down the belt tension adjusting bracket but I couldn't figure out how to pull it out.
Would anyone be able to chime in on removing the idler pulley and the tension adjuster? It is located in a deep corner of the engine bay so I could not get a good visual in that area. It seems that I need to replace something similar to this one.
https://www.ebay.com/itm/35389972501...mis&media=COPY
Or maybe just the bolt if I can find out the size of it. It looks like an M8.
