9 Attachment(s)
Re: Collapsed lifter(s) JOB COMPLETE
JOB COMPLETE!
Whew! Glad that is over with! Van is finally out of the shop after having all 8 lifters and rods replaced with OEM parts. Tried to use NAPA lifters to begin with but they DID NOT work at all. Engine misfired and would hardly idle. Forked out the $$$ for Toyota lifters and just like that, it runs beautiful. The extreme diesel like tapping is gone--replaced with a nominal tick tick tick of a normal sounding engine. The difference in performance is outstanding. It is almost like I have a new transmission. It runs smoother and accelerates more evenly. It also tops out at a higher RPM (5000+) when getting up to highway speeds and is a lot quieter doing so.
The attached pictures show how sludged up this engine is. The tech ran everything he took off through numerous parts washings and lots of goo was removed. Still. This engine was not cared for by its previous owner. I have a feeling that instead of regular oil changes she simply 'added as needed'. I need to do plugs, cap, rotor, and wires so i am fresh there and I would really like to do the timing chain. Hopefully I can squeeze some more life out of this engine before it inevitably siezes up. You can't really tell by looking, but the tech said that none of the lifters were functioning as they should. He said some were worse than others and they were harder to pull. The engine mounts were done at the same time and that is making a noticable difference in ride quality too--lots quieter.
Re: Sounds like a diesel at startup.....
I've been lurking on this wonderful website a LOT. Thanks to Tim and everyone for providing the information to keep my van running and give me the confidence to tackle my noisy valve lifters.
I used the JC Whitney tool referred to above. On most of the lifters, it was easier to just fish them out with a magnet. The tool was too long for the rear two (as JFratzke mentioned) and of course it was the 7th one back that was stuck. So I bought a bolt that matched the thread on the handle (5/16 x 24 I think) and cut off a smaller bolt as a spacer. My 3" bolt was too short, so I welded on a 3" rebar T-handle and now have a perfect lifter-remover for the van.
The tool doesn't really grab the "lip" inside the lifter because you can't compress the lifter when it's full of oil. You just expand the tool the best you can and hope it doesn't slip out. Maybe you could remove the clip and piston on a lifter that was really stuck, so you had the lip to grab onto?
The van runs SO much quieter now, I don't think I realized how much of the racket was caused by them. So far the Enginetech lifters I got on Rockauto for $20 for the SET are working fine, time will tell if it was $380 well saved vs. OEM.
P.S. I'm still running the OEM stereo too, it's totally worth it to have the remote volume control between the seats! I just use a Bluetooth player to play music on my phone since the cassette died long ago.
Andreas
Enginetech lifters...check. God those Toyota ones are expensive.
...wondering if mine has the same dieseling sound?
..here's a short video that catches the sound.... https://www.youtube.com/watch?v=Wu2z...ature=youtu.be
You can hear it best at 0:07 to :15 ,, and 29 to 34 seconds ....whatchathink? :cnfsd:
It goes away after ~5 minutes of driving.
micah202
..... anyone? :cnfsd:
Does the sound happen only when cold and then go away after 3-5 minutes? If so I am sticking by piston slap. noise goes away because as the metal expands (piston) there is less clearance for the piston to move and thus slap the cylinder walls. Aside from annoying it did not impact the 87 Van I owned for 13 years Got it new on 11/10/86 with 6 miles
At 20000 miles the piston slap developed and went another 12 years until it got stolen with over 300K miles on it. It was recovered and the insurance totaled it
JPERL
...yeh,, I'd say 5 to 8 minutes. I do consider it a reasonably normal sound for toyo's,, just wanted to worry about something else when I saw this thread.:yikes:
...the baby's at the mechanic's now for a full checkover,, it'll help me get over my paranoia's.
.... no head gasket issues,, no startup issues,, all he found was a balljoint to replace :thmbup:
......you still driving that one owner '86?
