Re: Radiator for 87 van LE 4WD
All the threads say pull the radiator out from underneath. There is a far easier way to do this. Remove the passenger seat ( 4 bolts, the back closest to the door is a stud , the nut is in the wheel well. Then, Remove the passenger side engine cowl ( a dozen bolts or so) You dont even have to disconnect the transmission shifter, just slide the assembly and cowl aside and the whole engine is open to work on. remove the fan shroud ( two pieces, the bottom unclips and then the top slide out easy). Pull the hoses. Unscrew the two retaining nuts on the bottom and the center bolt on top. And the radiator slides right up and out. Easy Peasy
liquidlights
[...]Remove the passenger seat [...] Remove the passenger side engine cowl [...]
And here's the detailed post on how to do that!
I got quoted $459 for a high efficiency recore by a shop in the bay area that seems to have a good reputation. I asked if it has 3 or 4 cores and I think the guy said 2 :cnfsd:. But he went on to say it had more fins per inch or something than the other recore he could do for $379. I am not sure if I should go for it or send out for the Ability in yuba city with known good results. It would be nice and more convenient to deal with someone local. Any thoughts on the efficacy of a 2 core 'high efficiency' radiator in the 4wd van?
Burntboot
Not sure about 2WD's but on a 4WD the condensor is mounted horizontally, ahead of the rad area and the fans blow down.
Can't see how they would do anything to help the radiator cool better.
So AC condenser steals air from engine radiator? Robbing Pierre to pay Paul? Some ducting seams to be called for down there!
Toyota used different configurations on different vans. My 89 2wd cargo van and my 86 2wd LE have dual air (front & back) and that system uses 2 condensers. One laying down horizontal and another mounted directly to the front of the radiator. I'm not real crazy about this as the condenser is dumping all that heat directly in front of the radiator. Not like they had a lot of choices for location though (only so much room under the front of these things). IMO not much you can do to improve ventilation unless you get real crazy and put one on the roof or something.
