Re: 1985 PARTING OUT. FIRST DIBS PUT IN YOU'RE REQUEST
Gingervan19
What are the mesure?
The measurements for window. I can't find tape measure but I can tell you its not the door window it's the larger panel side. The door window sold already. On the locks I have all 4 of them.
fuquan
Do you have the power steering pump? If so, is it Toyota?
No pump. I still do have alternator.
fuquan
Does anybody know if that would be the same for 87-89 4wd vans as it was in the 85 vans?
NOT the same. 87-89 has some different connectors (won't mate with the '85). Wires are the same, though.
Brake porportioning valve ?
Maxisback
Where at in the van douse it go? Never heard of it.
Motor, and the actual sunroof still available?
Banderson
Those parts not available sorry. Good luck
On the sliding door track, at the end of the track, there is a trim piece maybe 3-4 inches long (closest to the taillight). Do you have that piece?
jdweasel47
I don't have that piece sorry. Good luck
did the fog light switch disappear yet ? ... and, the antenna - does it have any kinks in it at all ?
Hi
Do you still have the sliding door handle? Will that work on an 86?
If so I'd like to by it
Jeff
slowstreamin
Hi
Jeff
Just the interior. No exterior
Tan Van
Dint come whit fog lights. The antenna looks good if you have the wire to swap can send a pic if you want
jdweasel47
Sorry no trim
Banderson
Sorry late answer. Was really busy. Motor for sunroof? Or engine? No sunroof.
dogger562
Thanks, I better take another look at mine (does the wire disconnect ?)
Still have the Dash? If so I would love to grab dibs! I can pickup in the near future!
Hello,
In the process of fixing up an '85 Toyota Van.
I'm looking for a center arm, as mine is shot. Would you be willing to sell this to me?
http://repairguide.autozone.com/znet...5280081ad3.gif
https://scontent-sea1-1.xx.fbcdn.net...cc&oe=5AACD002
how about rear defogger switch, still there ??
Re: 1985 PARTING OUT. FIRST DIBS, PUT IN YOU'RE REQUEST
Looking for:
antenna w/cable to radio. oem
locking mechanism for rear door
o/d switch on shifter or whole thing
Kevin
