Burntboot
Tim is right on, again.
Mark - It's good that you've narrowed it down.
What were the pads like that you took off?
Was the material worn evenly or tapered along their length, inboard vs outboard and LS vs RS?
You mentioned the callipers seemed crusty, did you service them while you were in there?
You likely had to compress the pistons in order to get the new pads installed, did all the pistons move freely and equally?
Did you crack the bleeder screws loose to push the pistons back? If so, what did the fluid look like?
At one point you mentioned some missing pad hardware, has that been corrected and does it affect the RS?
What does the rotor surface look like? Any rust/pitting/pad imprints?
Did you replace them or have them turned?
Is the noise a sound only or do you also feel it, either through the brake pedal, steering wheel or seat/floor?
Does it pull or fade to one side while braking?
Does it track straight when not braking?
And most importantly, does the noise change when you brake.
