Previologist
I noticed something I hadn't noticed before, namely that the FSM calls one of the lower strut-to-knuckle bolts a "set bolt" and the other an "adjust" bolt, and they differ in both structure and torque. Nowhere did I find clarity as to which was which, the upper or the lower. I took the bolts out and confirmed that, as I remembered, that they were identical bolts. I decided the top was probably the set bolt so I torqued that one to 232, and the lower one to 163 ft-lb. I do not recall what torque I used on the other side several months ago, but pretty sure I torqued them both the same.
