Re: Possible thermostat issues.
If the van warms-up and the heater blows hot air, then it's not related to the thermostat. It could be a failed air valve (between the intake manifold halves). When the coolant is cold, the air valve allows air flow (increases idle speed). When the coolant is hot, the air valve closes and prevents air flow (slower speed). To test, warm the van, then pinch an air tube going to or from the air valve. If the idle speed goes down, then you have a failed air valve. Tim
Hey Tim,
Is there some trick to testing (or getting to a hose to pinch)? I pulled an idle air control valve off a junked van and brought it to my mechanic with the FSM, but he insists there isn't a way to access any attached hoses to pinch to find out if the one already in my van is faulty. Instead, he says he somehow tested the ohms on it and decided it was functioning properly. Is that possible? I don't know what else would cause my idle to increase as the van warms up. Unfortunately, neither does he.... Any thoughts?
isaiah44
Hey Tim,
Please refer to post #48 in this thread.
Please refer to post #16 in this thread.
Thanks. Has anyone had this issue with their van - idle continues to rise as the engine heats up and doesn't ever return to normal - and had it be due to something other than a faulty idle air control valve? My 87 won't pass smog bc the idle won't stay in an acceptable range and my mechanic says it's not the IACV, but doesn't have any other suggestions. Up against a wall here, any help would be greatly appreciate. Thanks!
Idle Air Control Valve and passing Smog Check
Hi all,
We are in process of getting our van registered in sunny California (originally from Manitoba, Canada) and we are being failed on our smog check because we had built our own replacement for the IACV when it failed years ago. The smog parts locator wants $180 for a "reconditioned" IACV, which seems ridiculous. The part number is 22230-73010.
We were wondering if anyone has a line on a 85 (or compatible) valve somewhere in the Bay Area or has an extra we could purchase.
Erik and Helena
Re: Idle Air Control Valve and passing Smog Check
Supposedly this part is NLA from Toyota.
Sometimes they pop-up on eBay. Otherwise might be a junkyard quest item.
< The smog parts locator wants $180 for a "reconditioned" IACV, which seems ridiculous.>
This might actually be a good deal if your van is your only vehicle and needs to be fixed asap.
Read this thread (if you haven't already):
https://www.toyotavantech.com/forum/...ight=air+valve
Good luck!
erik
Hi all,
Erik and Helena
Wow, These parts are pretty much extinct in the sense the IAC for the van is unique in that it is not shared with any other vehicle and so your best bet is scour the salvage yards assuming you can find any vans as they are now as rare as a hens tooth. Maybe eBay, although I just searched and found nothing. I would say if they sourced one for $180 grab it as its probably one the few left in the world because that is still less than what Toyota would charge if it was still available from Toyota.
Is the van idling high? if not, I am guessing it failed the visual inspection of the emissions test as a "missing component" and not that the Van was actually putting out higher emissions as a result of having a modified IAC? As long as you can set the idle at 850 or below that should be acceptable for passing emissions.
Hi all,
Thanks for the replies. Yes, we are well within the emissions output limits (better than average!) and are failing due to "modified emissions control components". To be honest, I think that the whole visual check thing is a bit ridiculous, if I'm not polluting what should it matter what parts I'm using.
Anyhow, after some calling around I found an 86 at a junkyard near my work. Does anyone have instructions for how to get to the IACV? It's been years since I removed the original one from our van and I didn't put my replacement back in the same spot. I seem to recall needing to remove the intake?
Erik
erik
Erik
Again, read this thread. The reason I linked to it is because it has pics and advice on how to remove it.
Re: Won't idle when cold / auxiliary air valve / idle air control valve
I know it's a long shot... But does anybody have an extra auxiliary air valve sitting around (22230-73011) they'd like to sell me for a good cause?! 😁
Hi Tim, im trying to troubleshoot this part from my van also. I thought its opened and closed from an electrical signal, but what im getting from this (and the off vehicle testing method in the manual) is that its temperature sensitive and opens and closes based on the temperature of coolant flowing through it? Im a bit confused as to how it actually works. I “tested” my AA valve by hooking it up to a battery and nothing happened. When i was running the van last winter (never actually drove it) it idled low when cold and wanted to cut out, but seemed to get better as it warmed up. Any thoughts?
Thanks, James
As with many things in the FSM there is some information, but not enough to completely understand function. This leaves a little room for interpretation/speculation, which I'll leave to you. Here's what I know:
The auxiliary air valve opens when cold and closes when hot. There is a "shutter" or "gate" inside that allows or disallows flow. There is a spring constantly pulling on the shutter/gate trying to close it, but there is a bi-metal "stop" preventing closure. There is an electric coil (heater) wrapped around the bi-metal stop and when 12V DC is applied it heats the bi-metal stop as to promote movement towards the closed direction. There is also coolant flowing through the valve body and when the vehicle is warm (approx 180°F) this also promotes movement towards the closed direction.
Is the electric heater coil by itself enough to close the gate? FSM doesn't go there, so I don't know.
Is hot coolant passing through the body enough to close the gate without power to heater coil? I don't know that either :cnfsd:.
If either method were enough, why would there be 2 ways of heating the air valve? When I speculate, I have to assume both are required to achieve complete closure (but don't know for sure). The only tests shown in the manual are to check continuity of the electric coil. They say to check it warm (176° F) and you should see 40 - 60 ohms. They also say to start the van and watch RPMs while alternately obstructing/allowing air flow. When cold you should see RPM's drop when obstructed. If hot RPM's should remain constant. The manual also goes on to say the valve should be slightly open at room temp (68°F). Of course you cannot check that unless you pull the intake manifold.
As with any moving part, after 30 something years of service it's easy to understand how things could get gummed up and fail. If the valve is removed and at room temp (68°F), when you look through the bigger air passage holes, the shutter/gate should be slightly open. When putting an engine together, since this part is NLA, all you can do is check physical condition, continuity, and look through the hole (at room temp) to verify it's slightly open. If the shutter is slightly open stick a scribe in the hole and force the shutter to full open, then verify spring pressure closes it back to the same spot it was before. As long as the travel is free/consistent, and assuming it passes visual and continuity tests, then put it back into service. If it fails any of those tests, then start looking for another one that will pass. Tim
https://i8.photobucket.com/albums/a2...psxtbwmlod.jpg
https://i8.photobucket.com/albums/a2...ps5rknw7ak.jpg
Thanks for the response, Tim. Well written as always, haha. Looking at my air valve with the cover off, it appears the bimetal bar is warped towards the close position. The gate was slightly open at room temperature. I warmed it up with a hair dryer for a few minutes but didnt notice any movement. Maybe it just didn’t get hot enough. Next i might try throwing it in the refrigerator for a bit to see if it opens up. I tested the resistance and it was about 45 ohms at room temp. Im going to keep trying to figure this thing out, but if i cant then i might try rigging up a different kind of air valve from another toyota. Just a thought :)
Thanks! James
I tested my air valve when I had everything apart for the HG. IIRC, the valve still appeared partially closed when cold, but I was able to see it close by pouring boiling water through the coolant line.
