5 Attachment(s)
Re: Upper front arm - FEBEST good part?
filterway
Someone had experience with FEBEST upper arm?
Guess what?
Attachment 7443
Febest is German, yet they manufacture in China, and if you read the whole thread you'll find that whether from Crapazon or Fleabay or any independent they all come from China. The OEM are NLA from Japan too. If you order from Lakeland, Rockauto, or other online store they place the order to Japan , then they are told the part is NLA and cancel your order in an Email a week later. You have just wasted a week and they have made interest on your( as well as hundred others) money for that period of time.
The Febest is not a bad part, but when placed side by side with the Toyota you could question the quality and sturdiness.
Attachment 7438
The OEM is a lot beefier. After installing the Febests I started cleaning the OEM, just for giggles, What I found under the rust and dirt was some amazing pieces of casting. I flushed out the old crusted grease from the ball joint, and bearings by pumping WD 40 and laquer thinner through all the grease fittings (3). At this point, everything moved freely and smoothly no play, no squeak. I replaced as many bushings I could still find, re-greased and now I have the most expensive spare upper arms on the planet!:LOL2:
Attachment 7440
Attachment 7441
My point is if you can get your hand on a OEM set and don't mind getting down and dirty, you can get yourself the $220.00 original Toyota upper arms.
Carbonized
Ok thanks for your comment. I will probably go with OEM if i can :-)
