Radiator for 4WD
Hello toyota friends,
Parts are getting hard to find whether in the yard or parts place! My van has 293,000 and and had the 2nd
radiator.if anybody has the this part & the right one with lesser miles i hoped I'd like to know asap..You may
email or call me at 571 277 0109............
Thank you all,
Wesley
Re: Radiator for 87 van LE 4WD
My 4x4 van Radiator measures 13" x 24". I've been researching other radiators that will fit the van either as an upgrade or dual radiator setup.
So far I've come up with Mustang and VW Soirocco. Performance models are available for either of these cars.
The Soirocco has the inlet / out on the same side. I havent confirmed what size hoses yet.
For some reason the 4WD radiator (part #16400‑73170, replaced by part #16400-73190) is showing up as available on several different Toyota Parts sites.
I often use ToyotaPartsZone.com, which is showing the '87 4WD rad available for $421.72.
This may or may not be true, but I checked a couple other sites which also listed the 4WD radiator as available.
I don't know why it would be NLA, and then show back up.
TPZ is usually quite good at telling me when "The part you are looking for is NOT Available" !
Give 'em a call and see if it's true...
Rather than spend that kind of money on a stock radiator, I would highly recommend having the old one recored with a 4 row high efficiency core. Tim
What's a ball-park good price for a shop to do that job?
(just wondering...the cooling system on my new 4WD is fine, but the van is at the 'magic' mile mark of of about 120K...meaning all the random stuff that goes wrong after 100K will fall to me, the second owner...) :wnk:
Here's a quote from another thread:
llamavan
4WD Radiators. NLA from Toyota, NLA from everywhere else now, too, including 1-800-Radiator.
Solution — grab ANY 4WD radiator you find in a junkyard and stash it, even if you don't need it! (If you have an A/T van and can only find a M/T van radiator, there are people here and elsewhere who will swap with you. No sense in letting any more get crushed.) As long as the tanks are good, it can be recored.
Even better solution — send away your radiator, or a harvested one, for a high-efficiency four-row recore. This outfit has done several and is keeping the build specs (their ref #7403) on file:
Ability Radiator
260 A Garden Hwy
Yuba City, CA 95991-5500
(530) 673-0813; ask for Greg
I paid $342 plus shipping for one in mid-2010.
Hello online friends,
Thank you all for your response !!!! About my radiator, i did exactly what the majority suggested. I
had it RECORED and it's just as good as new! It cost $335. It was a blessing when i was calling around
and somebody referred me to this guy here in Manassas Va who does recoring work at his place.
If anybody needs recoring you can try calling John Sorrell 703 409 2813. Attached is a pic of my new radiator.
Regards,
Wesley
.Attachment 874
Attachment 873
The Ability Radiator at Yuba City, CA reportedly uses a high-efficiency 4-row radiator core that is manufactured by
http://jbrspecialties.com
J B Radiator Specialties Inc.
Sacramento, California
Phone: (916) 381-4790
My local radiator shop in north Los Angeles uses this same 4-row radiator core to construct 'desert racing' radiators which is popular with the desert racing crowd around Southern California (e.g., SoCal). However, I was told that this 4-row core allows for *less solder* to solder the water tanks on either side of the 4-row core. They actually suggested that the 3-row high-efficiency re-core would be a better choice for durability for this reason. To construct the 4-row high-efficiency re-core using my old radiator tanks was under $300 at my local radiator shop.
Has anyone ever considered jumping the AC fans to come on to supply more air to the radiator?
You could do this with a manual switch or a thermo switch. Easy if you already have an E fan on the radiator.
Not sure about 2WD's but on a 4WD the condensor is mounted horizontally, ahead of the rad area and the fans blow down.
Can't see how they would do anything to help the radiator cool better.
Has anyone here ever dealt with a cracked tank? One of my vans' right-side radiator tank has a small weep near the top. Tried cleaning it up and putting some JB Weld over it as a temporary fix, but it's having a hard time curing in the 40-50F temps here in the NW. Toyota Parts Zone lists a new one for $294.72; I'm betting it's aftermarket. Might try my usual parts source at Lithia in Springfield, OR. I have one recored by Ability, but it's buried *deep* in the back of my jam-packed storage space. So...anyone who has ever had a tank repaired, I'd be very grateful for the benefit of your experience.:silvervan:
It could be soldered. Maybe not now that it has jb weld in it. Take it to a radiator shop and ask em of it can be repaired. If not ask them to record it with a 4 row.
If this is for one of your 4wd vans then there's nothing available (not even aftermarket). Some parts sites may still list it but I'm guessing it will come back as NLA when you place the order. Like coronan says, when you have an issue with a radiator pull it out and take it to a radiator shop. They are the experts and if it can be fixed they will fix it. Never a good idea to put epoxy or anything else on a radiator, but I'm guessing it won't stick good enough to create a problem anyhow (probably come right off when they mess with it). Tim
Flounder
Hello,
These tanks are metal, like copper or whatever which can be soldered. Have you tried soldering? Better yet, depending on the radiator's
age, have it record and you get a longer trouble-free cooling system.
That's what I did !
W
Thanks very much for the info, gentlemen. I'm planning on trucking her down to Oregon in a couple of weeks. I can virtually wipe off the JB Weld, fortunately it was cheap...if I had a clean and dry shop to work in, I'd have already fixed (silver brazed) it. But that's about a year and a half away, on my property south of Chehalis.
wcalayag,
How is your radiator holding up so far? Im considering making the trip to manassas va and trying to get in contact with the guy you recommended John to recore my radiator in my 86 2WD. Its leaking pretty badly and I bought this new a year ago from an advance auto parts. :cnfsd:
Hope fully he can fix it?
Yeah, so I got the 4-row recore 5 years ago, and now there is a leak dripping from where the rows meet the tank on the driver's side. The radiator was showing up as available on a Toyota parts site, but they confirmed that it is NOT. Unsure as to where to get a radiator now, as my van is my daily driver, so I'm looking for another radiator to get recored so I can swap it in myself.
I am looking to buy a 4wd radiator.
I wouldn't condemn the 4 row radiator just because you got a leak after 5 years. Anything can leak in that amount of time.......could even be a core defect or workmanship issue. I'd pull it out and take it to a radiator shop. I'm guessing they can fix it up for around $150 or less. If your van is a daily driver, maybe you could call them ahead of time to set up an appointment to have it fixed while you wait. FYI, I've been running my 4 core radiator for around 10 years now with no issues (knock on wood). Tim
Tim where did you get your radiator re cored? If I get mine done I'll see if I can ship it to the same shop you got yours done from. All the shops around here suck or are too far
Mine was done at a local shop "Mac's Radiator" by a guy I felt comfortable with. Since then the shop has stopped doing work on location. They are still there, but they simply take radiators and transport to their Portland shop to have the work done on them. Once complete, they transport back to the local shop. I didn't like that so I switched to Wilson's radiator in Vancouver, WA. Those guys do their own work in-house and they know what they're doing. I haven't had them do any custom recores, but if I needed one I wouldn't hesitate to trust them with it. The core used in my radiator was a Modine High efficiency core & it's been doing good.
Due to the age and rareness or our vehicles, it's understandable that a shop may not be familiar with where to get the core. That's why it could be important to know who makes the product you want. For the 2wd it's the Modine core, and for the 4wd it's J B Radiator Specialties in Sacramento (MonTex posted earlier in this thread). Armed with this information, any competent shop should be able to obtain parts and do the recore. Tim
I recently spoke with a local shop about doing this. I've had them do work before and been happy. He explained how they would do the four row by splitting the corners of the tanks to widen it. When I told him I had a spare radiator that had pin holes all over the tanks he said, "No problem, I can get new tanks made." I didn't inquire as to cost and haven't been back with my other radiator yet to ask any more questions but I would assume this opens the possibility for a completely new radiator with tanks designed to accommodate a four row core. When I take my radiator in I'll ask more questions and post the answers.
I'll talk with a radiator shop this week about what can be done. It looks that my Flex-a-lite dual fan setup that is held on by plastic strips through the fins is to blame. What happened is that the driver's side fan is barely resting on the differential, putting upward pressure on the rows over there. I'll try remounting after the radiator is fixed.
Tim, that custom aluminum shroud of yours would be nice, but I'm just glad the move to Nevada went without any issues.
Where in Nevada are you?
If your in Reno, I can help.
I fitted a Corolla Radiator into my van. There are pics on here somewhere.
Got electric fans yet?
I actually am in the Reno area! Your Corolla radiator install has some nice fab work there. I am keeping my front diff in, so that wouldn't fit. I would be interested in your old radiator if you still had it. Private messages work on here, don't they?
Yes, I've been using electric fans for years, and find them to be far better for cooling at low speeds. As I mentioned in my last post, I think the way I mounted them led to my current trouble. My van's been pretty reliable for several years now, thus my absence on the forums.
I already sold my old radiator.
But I still have my e Fan schroud if you need.
The plan for my van is to lift the front 2" and fit a 4Runner diff. Someday when I have time.
The stock front diff came out when i regeared to 4.88's. Best mod Ever.
Limited slip in the rear gets me down 90% of the trails. Unless I am doing something stupid.:?:
I had 5 or 6 of those radiators sitting in a parts van (all good usable cores). When we moved about 3 years ago it took us about 10 days to get everything off the property. During that time metal thieves came out and stole all my radiators, cats, and differentials out of that van (among several other things) :pissed:. Such a shame as they were 4wd auto diff's (great for swapping into manual vans with big tires) and 4wd radiators. Of course I'm sure they're all melted down by now. All the thievery is the biggest reason we moved from there. At least what I have left is finally safe. Tim
Hey Coronan,
Didn't you sell that shroud last summer- Or was that someone else? I'm interested in it if Wonderwagon is not.
Aaron.
I'm not interested in changing my shroud setup, I'll just mount it 1/4" higher and it should be fine.
Visited the local radiator shop today, but their specialist wasn't there. I'm hesitant to send it back to Ability Radiator in California and would rather deal with the local guys if I can. We'll see once I get the radiator out what the story is.
The local radiator shop fixed it by soldering up the rows that had broken off the tank. Only $50 and I'm very pleased with their service!
Ability Radiator
260 A Garden Hwy
just called these folks.... the fellow laughed, saying he hasn't done one for a year or two,, but I'm the 3rd inquiry this week!
Apparently copper pricing is 'out the roof'...current price, including return shipping is $439.....you provide the old radiator.
Anyone know of cheaper options for a 4 core high efficiency?
I'm in the same boat as everyone here. I need radiator fixes! I'm still trying to decide on shipping it out or driving to the nearest location. Also trying to decide if I want a recore or just swab out the one I have that doesn't leak.
Wish sh there were some choices to buy new!
I am have an 87' 4WD that runs hot and is burning oil. I go through about 1 1/2 quarts a month. I am also looking for a new radiator or a place in Los Angeles (or somewhere in SoCal) to get my current one recored.
-Derek
At $439 for a recore would anyone be interested in an aluminum replacement?
I have a local guy that makes aluminum radiators for race cars, street rods, and odd applications that I could ask for pricing. I'm guessing if we did 4 or 5 at a time it might help with the cost?
$400 is allot for a radiator unless you like your van.
It has been the going rate for a while. And most Happily pay it.
I'd be interested in an aluminum unit.
I'm running a celica radiator my cooling is improved but not perfect.
I would be down for one if the price is <$500.
...I might be down for one as well,, want to check local first,,
...what's the actual core size of the 4x4 radiator?
I'm also interested.
I'd like to buy a spare or two.
Tim
Ok, I'll swing by his place this week and see what he has to say as far as if it's something he'll do and what the price will be.
I'm in <$500 as well.
We're talking specifically about 4WD 5 speed specs, correct?
