Hi-
I'm having an issue with my van. First let me start off by explaining that a few months ago, I had my fuel pump replaced on my 1992 Previa. One issue I had with it was that the Check Engine light didn't come on at all. Tim said battery fuse box; my mechanic said fuel pump. I disregarded Tim's thoughts and went with the mechanic's: Bad move. I have been having intermittent issues ever since and everything went out last Thursday. Turns out that the box was bad my mechanic tells me after I should him Timsrv's posting and he tested it. When I went to pick up my van after the repair, my ABS light was on. I spoke to the mechanic and he asked if I could leave so he could look at it the next day. I agreed to it. The next day, I stopped by the shop four different times and they had one guy actually working on it when I arrived each time. They couldn't figure out why my ABS light is on. Does anyone here have any idea why the light is on? Like I said, it wasn't on before the repair so I doubt that there is actually ABS failure. However, I can't eliminate that option either. Any help would be suggested. Thanks in advance.
