the brother in-law and i will be going to retrieve my dead van in the AM.
story goes, replaced
cap
rotor
plugs
wires
thermostat
in and out coolant hoses
and cleaned up alternator and harness
drove her for 200 flawless better than ever miles and then...
small hiccups on take off, got worse as the day progressed, just a flutter of a no power, not a shudder, no noises, just like the damn thing was burping, got worse and worse till the engine finally just shut down( mind you, i was trying to make a ferry) got towed to town and dropped off at the local NAPA no noise from the fuel pump. road side i dropped the tank and replaced the fuel pump @#$%$#***&^%$# no buzz THEN checked the wire harness to the pump, no power...hot wired the pump and buzzzzz, my vans fuse block has seen better days, when i got it there was alot of burnt roflroflroflrofl that i worked around but this ones wierd, fuses blow, they dont shudder tilll they die
any thoughts????
j-
p.s. the dog didnt give a roflroflroflroflAttachment 492
