Here is the next most problematic fusible link. The FL 0.5G fusible link is the yellow connector going to the positive battery post inside your battery box. It is rated at 0.5G (based on wire gauge, I'm guessing about 20A). This protects the alternator sense circuit that links the battery positive to the
"S" terminal of the voltage regulator (built into your alternator).
If this link is bad or disconnected, the end result is solid "Christmas lights" on your instrument panel and a "full field" condition in your alternator. Full field is when the regulator tells the alternator to go to maximum output all the time and can be dangerous. A short trip probably wouldn't cause any problems, but long term use could cause multiple electrical problems (due to over voltage) and worse case scenario could end with a thermal runaway condition occurring with your battery. Thermal runaways are scary and dangerous. The result is usually a pile of molten lead, plastic and battery acid all over the place. Thermal runaways have also been known to start fires, so don't push your luck with a bad or failing FL 0.5G link. Here is a what a typical 20 something year old one looks like:
http://i8.photobucket.com/albums/a23...v/IMG_0158.jpg
Although slightly more protected than the main fusible link, this link is still in a harsh environment and after 20 years or so will probably need some attention. I haven't checked to see if these are still available through Toyota, but really didn't see the need for genuine Toyota here. If Toyota still has these, they will no doubt want more $$$ for them than what they are worth. I have found a good substitute for these through
Summit Racing for $2.95. These PICO fuse holders are water tight and are rated at 30A. Since this is a "sense" circuit, there would normally not be any current here, so I am going to recommend using a 15A ATC fuse. Here are a couple of pictures:
http://i8.photobucket.com/albums/a23...v/IMG_0164.jpg
http://i8.photobucket.com/albums/a23...v/IMG_0155.jpg
