PS: Almost forgot, Since I like AC, I have my AC amplifiers on my vans cranked down to allow my AC to run at an idle. I've wired my compressor stators (magnetic clutches) in series with the "normally closed" side of a Bosch relay. I wired the coil side of the relay to the switched side of my 220 deg temperature switch. Due to the resistance of the relay coil, to avoid potential feedback, I wired it through a diode (prevents false alarms). If engine temperature exceeds 220 deg, the relay is triggered and the AC compressor shuts down. Since my "Idle-up" VSV is still activated, when the load of the compressor is dropped the engine RPMs increase to around 1k. This makes the engine cooling fan move more air (my 86 still has the fan clutch set-up), and this helps cool the engine. As soon as the engine cools down below 220 deg, the relay closes and AC operation resumes. This prevents accidental overheating in the event I leave my engine running with the AC on (if I run into a store for something) :wnk:. Due to my habits, an event such as this is rare for me, but due to Murphy's law, I actually had such a thing happen about a week after
overhauling the engine in my 86. As luck would have it, I came back to the van just as my overheat alarm was starting to go off. I made the "AC limit mod" shortly after that.
PPS: The above description of the A/C cut-off/Idle-up mod is the simple explanation. The actual circuit is slightly more complicated as I needed to incorporate a 10 second timer and a capacitor to get it to function correctly. If anybody is interested in this mod, let me know and I'll identify actual components and I'll draw/post a sketch of the completed circuit.
