Page 5 of 5 FirstFirst 12345
Results 81 to 99 of 99
Thread: Click-No-Start (Starter, Ignition Switch and other Culprits)
  1. #81
    '88 4x4 5 speed manual
    Dec 2018
    ME
    Re: Click-No-Start (Starter, Ignition Switch and other Culprits)
    ah, thanks for clarifying and the extra detail Tim!
  2. #82
    1989 Toyota Eli
    Vancouver, BC
    I was having an intermittent start issue and after reading the posts and going through the steps finally found success with a new ignition switch. Or so I thought. After a few months the problem came back. Went back through everything and out of curiosity installed a second ignition switch and the problem seemed solved again. Now I'm having the same problem again. Any clue as to what could be damaging the ignition switch?
  3. #83
    Sir goofy,
    I would suspect yours may be a situation of the sum of all things. As Tim discusses in post #45, the resistance in the circuit builds over time with age and even small amounts of corrosion. Eventually you aren't getting enough voltage to the starter to adequately energize the solenoid. By changing the ignition switch you may have reduced the resistance by just enough to fix it until the new part started to get a little wear. Also in post#45 Tim explains how to install a Bosch relay kit. These were originally designed for air-cooled VWs to alleviate voltage drop from age and the distance the current had to travel and work well for their intended purpose. I have personallly installed a few of these( including one on a Subaru) with good results and will putting one on one of my vans soon for the same symptoms described in this thread. Might be worth looking into.
  4. #84
    1989 Toyota Van LE
    Jul 2019
    Baltimore, MD
    Hey all!
    I am the relatively new owner of a 1989 Toyota Van LE. I’ve been having intermittent starting issues with the “click.” After a couple tries, it normally starts, but I was left high and dry once a couple weeks ago, only getting it to start after hours of tinkering. The battery was old, so I replaced it, which I thought solved the problem but just recently started having the same issue again. The thing I haven’t seen mentioned here is that when I remove the positive battery terminal connector and re-mount it, the van always starts right up. There is some light dust on that terminal each time I remove it, so I think I will replace that connector today. Could remounting the connector be sparking a bad starter enough to ignition? I’m trying to figure out other causes of the issue in advance as the ol Van is my daily driver.
  5. #85
    If corrosion is growing on the positive post in days/weeks as opposed to months/years then you likely have a failed battery post seal.
    You may try to get warranty on the battery but will depend on supplier as that fault, especially on a new battery, is usually caused by improper tightening of the battery connector.
    Usually happens when people get aggressive tightening the connection and it applies a side load to the terminal enough to cause the seal to breach.
    Using a 4in long 10mm wrench and making it "tight" (without supporting the terminal with the other hand) is more than enough to break that seal
    The fact that disturbing the battery positive connection solves the issue, would tend to indicate its that connection causing your (current) issue.
  6. #86
    Searching, hoping, waiting...
    May 2019
    los angeles
    Does anyone have any tips for removing the actual starter? I read Tim's whole post on replacing the worn contact and got the part from Toyota - $16!. But now looking at the starter itself, (which looks to be nearly under the passenger seat), it seems really tough to take out.
  7. #87
    The White Buffalo - '87 4WD 5sp window cargo
    Oct 2018
    Oakland, CA
    I have no experience with starter issues, but your comment makes me wonder if you don't know how to remove the passenger side access panel? If not, search the forum - it's easy, and greatly improves engine bay access
    How Can The Radiator Light Be Real If Our Eyes Aren't Real
  8. #88
    Feb 2016
    Los Angeles, California
    Quote Originally Posted by gwalzer View Post
    you can easily access it from underneath. I believe only two bolts keep it in place. Should only take a few minutes to drop!
    Name:  Screen Shot 2019-07-10 at 4.24.33 PM.jpg
  9. #89
    1987 toyota van le
    Jul 2019
    nj
    STARTER MAYBE
    Hello i have a 1987 toyota van 4wd. we havent really taken out for drives yet. but we start it up all the time. fixing things here and there but lately car took a little bit to start makes noise like it wants to start and eventually starts. but now it doesnt want to seem to start. makes the noise like it wants to start but just doesnt turn over. do you think it may be the starter? thanks for any info. i was trying to search starter in the forum im sure there is somewhere with diagrams and such but couldnt find it. thanks again
  10. #90
    Have you checked basics like battery voltage?
  11. #91
    1987 toyota van le
    Jul 2019
    nj
    yeah battery is brand new changed it like 3 months ago
  12. #92
    But what is the actual voltage as measured at the battery? Also, it's important to clarify your terminology, i.e. "makes noise like it wants to start". When you turn the key does it only make a single click sound and repeatedly cycling the key produces the same single click with each cycle? Or, when turning the key does the starter spin and turnover/crank the engine but it doesn't actually fire/start?
  13. #93
    Dec 2018
    ME
    anyone ever spec out Tim's mega ground wire on Page 3 of this thread?
    He mentioned 2/0 gauge wire - but it would be great to get lengths, lug sizes, bolt sizes to replace rusted or missing ones + I think he did shrink wrap at ends etc.
    OR
    do I just grab the 2 circled items from RockAuto, which will be smaller gauge but save a bit of crimping etc.
    I just started getting the click click issue, and my ground (below) certainly would fall in the suspect category so starting there. Looks like someone did a rebuild and bypassed the whole middle bolt to body.
  14. #94
    Without already having the proper tools to crimp with, sourcing pre-made cables makes sense.
    Most auto parts stores carry pre-made lengths that can be utilized, while they might not be the perfect length, they will ge the job done.
    No doubt those RA cables would work fine
    Pre-made cables will come in standard lengths (12,18,24"....)
    Custom made cables will get you a cleaner install and allow you to spec whatever wire size you want, there's likely an electrical shop near you that would make them up for a small fee. You will need to supply them with lengths, eyelet sizes etc
    Something to consider.
    I have seen cars that had ground wires rust off like yours, more often than not they would come in with the accelerator cable smoking/melted because it was acting as the ground.
    Its worth taking a look at all things that may have been acting as a ground (kickdown, accelerator....) just to make sure nothing else is compromised.
  15. #95
    Either way you will need to take some measurements to get the right sized cables as you will need battery to frame and frame to engine.
    I always add a 2nd ground off the other side (chassis to drivetrain), likely not required but I like a little redundancy, sometimes.
    Given that the positive wire is the same age, might be worth inspecting it while you're in this deep.
  16. #96
    I had the speedometer cable and instrument cluster act as the battery ground on an '85 Mercedes diesel once. It wasn't pretty.
  17. #97
    Click no Start
    I was heading out to work and this happened to the TownAce, the issue has gotten worse over time so here’s a couple short videos for reference-
    https://www.youtube.com/watch?v=U22T6g8keho
    https://www.youtube.com/watch?v=p8vJU69BM1w
    Time for a new relay and wiring “I ain’t got time for clicks”
    https://www.youtube.com/watch?v=er-bLwQ7EvM
    Just for clarification I dropped off the van and had my MasterTech to complete the work.
    1987 4wd 5spd
    Apr 2021
    I just finished repairing the Click-No-Start issue that suddenly appeared on my Van. This thread was immensely helpful in me diagnosing the problem. I thank you all everyone who has contributed to this thread. It turned out to be the starter cable was corroded. There was a portion of the wire insulation that rubbed off and corroded the wire. It was a portion of the wire that ran up and over the transmission so i wasnt able to see it until i removed it. I havent read every single post on this thread so this might have already been said, make sure to check for continuity or voltage at the starter cable without turning the key. I stupidly only checked for voltage while someone was turning the key and falsely thought the starter was getting power. It appears that voltage will pass through the switch wire and solenoid into the starter cable and make it seem like it has power. Since i thought it had power i went on to diagnose the ignition switch and clutch pedal switch which turned out to be a waste of time. Now that its fixed i plan to replace all the grounds and also the alternator cable since i noticed some frayed insulation on the grounds.
  19. #99
    Forum Newbie {LG}'s Avatar
    1988 LE 4WD
    Jul 2019
    Missoula, MT
    Same, this has been a most helfpful thread. Many thanks to all who have contributed.
    What fixed this for me in the end was ridiculously simple- I cleaned the connections and reconnected the ignition switch. Haven't had click no start since.
