Page 4 of 4 FirstFirst 1234
Results 61 to 71 of 71
Thread: The Fan Clutch (clutch fan / fluid coupling) Thread
  1. #61
    Van Fan bushcat's Avatar
    '85 Toyota 2WD Cargo Van ------------------ ‘84 Toyota LE Van ————————
    Dec 2017
    Benicia, CA
    Re: Fan / fluid coupling (fan clutch)
    Do you need a special wrench (and or any special tools) to remove the fan clutch on these vans? I think mine needs replacing.
  2. #62
    Van Fan Tan Van's Avatar
    1987 Van 2-wd
    Sep 2014
    Milwaukee, Wis.
    Ordinary tool sets probably won't reach it, but, the guy across the street is a Honda mechanic and had 2 really old box-end wrenches that were super long and thin... both were 6-point 10mm wrenches with only a one-sided wrench and just a long shaft on the other end ... about 12" long... the "Honda" brand wrench was close but no cigar, and the "Snap-On" brand wrench had more offset and just barely worked. With it I was able to pull the clutch and fan off the water pump without moving anything else at all. It would be worth buying one long wrench if you can't borrow. The 4 nuts were already a bit rounded from some previous butcher, but, you can reuse the fan-attaching nuts for the "clutch-to-water pump" studs and buy new flanged nuts for the "fan-to-clutch" studs. I was able to wiggle the clutch and fan as one piece in and out of the bottom of my 2wd van... which now makes me wonder if my entire shroud is still in place.
    Update:
    Wow---it's missing... (The bottom piece of my shroud)
  3. 02-03-2018, 08:41 PM
  4. #63
    Dec 2017
    Benicia, CA
    Quote Originally Posted by Tan Van View Post
    Update:
    It was 9 degrees this morning so I don't care right now, but, a Spring-project is in the plan...
    If anyone has a cool home made shroud-bottom can you post a photo and a "how-to" ?
    Thanks TanVan. Looks like the autoparts store rents fan clutch wrenches. Do people usually replace the water pump when down there?
  5. 02-03-2018, 09:57 PM
    Reason
    off-topic posts moved to new thread
  6. 02-04-2018, 12:46 AM
    Reason
  7. 02-04-2018, 01:35 AM
    Reason
  8. 02-04-2018, 02:44 PM
    Reason
  9. 02-04-2018, 03:31 PM
    Reason
  10. 02-04-2018, 05:23 PM
    Reason
  11. 02-04-2018, 10:43 PM
    Reason
  12. 02-05-2018, 05:03 AM
    Reason
  13. 02-07-2018, 05:25 PM
    Reason
  14. 02-07-2018, 10:20 PM
    Reason
  15. 02-28-2018, 11:21 PM
    Reason
  16. #64
    Forum Newbie Grappler's Avatar
    1987 Cargo: 'LOLVAN'
    Re: Is my brand new fan clutch a dud?
    HISTORY Just finished fixing all culprit issues associated with overheat, fan clutch, belts, water pump, radi cap, thermostat, hoses. Runs just fine and behaves normally EXCEPT ...In traffic or other warm-running situations, the gauge creeps. In Los Angeles, this is going to be a double-whammy issue as spring/summer approaches, so I want to figure it out right now. My fan clutch very audibly is engaged after a cold start, so I know it CAN work, the thing is, after the temperature gauge gets past half, I never hear it again and a quick test right after I shut it off gives no resistance. Soooo, is it possible that the clutch in there is just a dud? Could I have done something dumb or wrong? is not enough hot air getting to the bimetal tstat? (radiator clogged up?) It's a brand new (less than 500 miles) Aisin clutch from RockAuto.
    HISTORY, PART TWO -- I was sitting in low speed traffic, and the thing did come on right after the temp gauge hit halfway --- hmmm. It's worth noting that it's never overheated, but it's gotten too close for my comfort on several occasions, usually at around 25 mph on a congested freeway. Before I did the work, the temp gauge would live at 1/4 of the way up (presumably from a stuck open thermostat.) Any thoughts? Am I just being scared over nothing? My next step is to blast the front of the clutch with a heat gun and see if the bimetal moves predictably.
    RESOLUTION I did learn a bit about fan clutches and, at least in my case, the Aisin FCT-37 I had (with the red mount) never worked in my 2WD auto application.
    I discovered this after being (again) hyper sensitive about the van cooling, and noticed that no matter the situation, the red back clutch never activated unless it was a cold start situation, when the oil viscosity locked it on regardless. While idly online shopping, I saw that there was another AISIN clutch fan listed as fitting the van, the FCT-19, which has a black mount and seemed slightly smaller. I did some research and saw that it was listed as stock for the very early (2.0, likely) motors At the time, it was somehow listed on amazon for $15 (whoa!!) so I grabbed one just to experiment.
    After days and days of garbage heat and me relying on the A/C, the new clutch fan works exactly as it should. It comes on post freeway drives, in stop and go, and when heat from the condenser gets to it. The FCT-19 is definitely physically smaller and less heavy duty (see side by sides below) but it works perfectly, so it's a keeper for me.
    Has anyone else had this experience, used both, or did I really just end up with a weirdly defective AISIN product? It seems highly unlikely, but I can't explain it otherwise.
    Last edited by llamavan; 11-03-2018 at 06:01 PM. Reason: had to stuff three posts into one to allow smooth thread merge
  17. #65
    Van Enthusiast boogieman's Avatar
    abq, nm
    my aisin fan clutch seems to engage more often at a lower temp than needed, i thought at first maybe it was the aluminum radiator dissipating more heat onto it but that doesnt seem to make sense, i thought about trying to tweak the bimetal valve but decided to leave it alone as at least its erring in a safe direction...
    the fan clutch in my 85 which doesnt get driven often is always engaged...i believe its an aisin as well, so i guess they fail in different ways...
  18. #66
    1987 Van 2-wd
    Sep 2014
    Milwaukee, Wis.
    my aisin fan clutch seems to engage more often at a lower temp than needed...
    I bought 2 separate brand new Aisin clutches ,(red), that both ran way too long after startup-- sometimes for 2 miles or more in the dead of winter on every startup even when the engine was already warm...
    I opened it up and drained about 5 or 6 cc's of the silicone fluid out of it and tried again. The new (RED) Aisin clutch just had too much fluid in it from the factory. I got lucky with my estimated quantity to drain because, now, the clutch fully engages only at startup -- it stops howling after about 15 or 20 seconds -- and, most importantly, I clearly heard it re-engaging this summer during really hot drives (high 90's and high humidity--freeway + street)!
    This saved me from the "crap-shoot" of exchanging it and trying a 3rd new clutch all within 4 months.
    (and, for reference, the van cooling system has no negative issues of any kind... and the front and rear heat also both work splendidly ---- the original clutch was always "locked on" which is why it was replaced ... and I expected the new aisin clutch to "fade out" after startup like it's supposed to, and it almost never did...and the replacement they sent was even worse... so, I saw the "silicone fluid tweaking" on a 4-runner site ---- and it worked.).
  19. #67
    Ivory 1987 Manual 4WD
    Sep 2015
    nowhere, everywhere
    Use Toyota #90916-03046 180 F T-stat. The gasket you need is #16325-63010.
    is Aisin OEM Toyota? or is Aisin aftermarket? ordering a few things from rock auto, but am confused on what's aftermarket or not. is toyota OEM only available from toyota?
    getting the aisin fan clutch and figured it'd be a good idea to replace some things that haven't been done while I have the chance to. (i have very limited mechanic experience.. which is probably obvious haha) should i replace the coolant hoses or anything else just for good measure or inspect them first? or since the fan clutch is confirmed not working, should i do that first and then see where my temp gauge is at before replacing anything else? i don't really have time to waste as this is already effing up my plans, but I want to be thorough so i'm not having ANY overheating issues since I'm heading to the south.
  20. #68
    Re: The Fan Clutch (clutch fan / fluid coupling) Thread
    Toyota buys parts from several outside manufacturers. Denso and Aisin are two of the big ones. Denso and Aisin make parts for other manufacturers as well (not exclusive to Toyota). In many cases, when you purchase parts from Toyota, The only difference is you'll get a red box that says "Toyota" AND you'll likely pay much more $$$. For this reason, whenever I can purchase OE equivalent parts at discount prices that's what I'll do. In the case of this clutch fan, Aisin was the original supplier to Toyota, so Aisin/Toyota are essentially the same.
    IMO, if you still have any original hoses they should be replaced. It's your risk though and also your budget, so use your best judgement. Good luck. Tim
  21. #69
    Van Addict Carbonized's Avatar
    wherethevanisrare. FL
    Quote Originally Posted by dirtritual View Post
    as this is already effing up my plans,.
    If I don't want anything effing up my plans, I make sure to plan around a thirty two years old appliance
    LG.
  22. #70
    87 2WD Van 96 Previa SC (RIP)
    Jul 2018
    Portland, OR
    Can anyone who has driven both a TV and a Previa confirm for me that the fan on the TV should sound, at startup, like that of a Previa? B/c I have never heard that fan roar from my new-to-me TV. I recognize it from the fan-clutch-related YouTube videos, though.
  23. #71
    Due to several variables the sound would be a bit different, but yes, both are clutch fans and should have a roar at start-up that goes away after a few good revs.
