I have two oil leaks. One is from the oil pan and that should be a relatively easy fix ( knock on wood). The second one though is a bit of a mystery. It's bigger and seems to be coming from somewhere around the front end of the exhaust pipe opposite of the oxygen sensor. I think it's actually coming from somewhere higher up than that because there is oil residue everywhere. Any idea of where it might be leaking from or how to find the leak?
