Results 21 to 40 of 54
Thread: What does a particular VSV do? See excellent attached diagram.
  1. #21
    Re: What does a particular VSV do? See excellent attached diagram.
    No. There are several recent threads about no start issues. You might try checking those out. Good luck. Tim
  2. #22
    Van Enthusiast gushaman's Avatar
    1987 LE 2wd capn chairs auto 1987 LE 4wd capn chairs 5speed Have owned:.......ive owned 8 other vans, i cant remember all of them sorry
    Dec 2010
    Nashville,tn
    Lol my plastic screw thingy is broken as well. I may invest some time in it. During a recent changing of a leaky fuel filter, i found what i think is the a/c clutch wire dangling in between the ac clutch and idler. I cant see the connection point, but the previous owner said the a/c never worked as long as he had it, i wonder if this is why, maybe it still has freon and i can get it goin. The chinese fuel filter had several pre crushed copper washers, im amazed it didnt leak before. i found a replacement for the e.f.i. forklift engines at work.
  3. #23
    Jun 2014
    Sahuarita
    Oh crap I broke my BVSV... Are replacements still made? This is a great thread btw!
  4. #24
    near Eugene, Oregon
    That's why it's most commonly called the "Oh crap I broke it" valve. Toyota part # 90925-05017. Still made as far as I know.
  5. #25
    Jun 2014
    Sahuarita
    Thanks Gwen!
  6. #26
    Administrator
    89' TownAce Auto 87' 4x4 5spd LE 87’ 4x4 5spd Cargo
    SEATTLE, WA
    Wow this is an excellent thread!! Definitely a 5 STAR thread....
    I don't understand the the detailed mechanics and operations but the easy explanations and pictures makes it comprehensible to a non-wrencher.
    Just my 2- I give this thread
    The 5 VAN THREAD AWARD
    Thank you
  7. 08-20-2015, 05:25 PM
  8. #27
    1989 vanwagon le
    Aug 2015
    northwest florida
    hey my plastic screw broke as well... anyway i can buy a replacement somewhere?
  9. #28
    If you're talking about the idle-up diaphragm, they have these on www.rockauto.com. Just drill into their database for van parts and in the "Fuel/Air" section you'll find it under "Idle Air Control (IAC) Valve". The expensive one actually is the air valve, but the cheap one is the "Idle-up diaphragm". Use the picture beside the part to help identify. Tim
    BTW: The early idle-up diaphragms have an adjustment screw but the later ones do not (preset). I personally like the earlier ones. Tim
  10. #29
    1987 4x4 TV.
    Feb 2015
    Hilo Hawaii
    Anyone know why my ISC VSV would go on and off nonstop after my van dies? It does this for several minutes after running for a few minutes then it dies.
    I replaced the switch with another and it continues to rapidly switch back and forth.
  11. #30
    87 4x4
    Jan 2012
    Reno, NV
    Is vacuum low enough at full throttle to raise fuel pressure???
  12. #31
    4x4 Cargo
    Mar 2016
    Cedar City, UT
    Does anyone know an alternate part that can be used for the Air Control Valve (part number 17630-28010)?
    looks like Toyota has it but its around 250-300 dollars
    theres quite a few of these on eBay and they're only 45 bucks, but who knows if they'll fit or not.... (p/n 17630-16040)
    not sure how part numbers work but they both have the 17630 part name code
  13. #32
    Quote Originally Posted by coronan View Post
    Yes, every time you step on the gas the fuel pressure goes up ~ 5 PSI or so.
    Quote Originally Posted by mistershmi View Post
    Not sure how compatible that eBay part would be, but these things hardly ever fail. Practically any van found in a salvage yard would likely have a good one. I'd recommend going HERE to see if that 86 van has got one. If so I'm guessing they'd let you have it for under $20. Tim
  14. #33
    4x4 Cargo
    Mar 2016
    Cedar City, UT
    mines probably okay, what would be a symptom of a bad one?
    i probably don't actually need to replace it, I'm just in "replace everything in sight mode" because of the PO's negligence and lowest bar possible approach to their work on the van ha ha
  15. #34
    It mounts to the power steering pump and it opens/closes an internal valve when power steering pressure goes up/down. The valve blocks/allows vacuum flow to the idle-up diaphragm (same thing the AC idle-up VSV does). The increased RPM keeps the van from stalling due to momentary heavy loads imposed by the power steering pump.
    For instance, say you're sitting in a parking lot with the van idling. For whatever reason you grab the steering wheel and start cranking it (without rolling forward). This creates a pressure spike and momentary heavy load from the PS pump. If the idle speed were not increased the engine would likely stumble or stall. The job of this part (in conjunction with others) is to prevent that from happening. Tim
    PS: Read posts #10 & #19 (1st page of this thread)
  16. #35
    4x4 Cargo
    Mar 2016
    Cedar City, UT
    Oh man whoops, i must have skimmed past those.
    I'm learning a lot from your comment and those referenced posts (and this whole thread) about how all this stuff works. Very valuable knowledge.
    I'm always amazed at your intimate knowledge of every aspect of these vans. Thanks Tim for all your contribution to the forum.
  17. #36
    My pleasure . What good is knowledge if it cannot be shared?
  18. #37
    84 Stick Toyota Van 84 Stick Vanagon
    Mar 2017
    Los Angeles
    OK so there are 3 VSV parts that I have to check. Right? The ones on post number 14. Whit an hmo meter, that I have never used but that I'm going to buy because I have a feeling it's a good tool that's gonna come in handy.
    My roadster has those symptoms, first out of nowhere it started idling really high like at 1400rpm whit out me adjusting anything, then I had to adjust air screw for temp relief but it's all out of wack.
    Symptoms 1=when cold most time I have to give it gas and will turn on, on fith or six try
    2= I have to keep pedal down a little to stay keep 1200rpm to warm or else it would drop to rpm500
    3=if I adjust screw to 1200 when cold to warm up. When does warm it stay around high rpm like 1400
    Can someone tell me if I'm at least heading the right direction as far as the process of elimination to deal whit this problem? Than you
    Dogger
  19. #38
    An ohm meter will only tell you if the coil inside is good. I prefer to test by blowing through the vacuum port (with my mouth), then I'll apply 12 VDC to the terminals and blow again. If the VSV is good you will hear a click when voltage is applied, then you will notice the air flow changes. Some VSVs will allow/prevent air flow (depending on valve position), others will direct flow to a different port and/or vent it out. Bottom line? as long as flow changes with voltage it's good. Tim
  20. #39
    Mar 2017
    Los Angeles
    Thank you Tim, I dint know how important VSV system is and the impact it can have on the performance of our vans. Definitely on my to do list.
    Dogger
  21. #40
    1989 LE
    Dec 2017
    Seattle, WA
    Tim, how does one go about adjusting the earlier one with the adjustment screw? My 1989 2wd LE has one.
    Mark
