Results 1 to 20 of 31
Thread: Lower Control Arm Bushings
Hybrid View
    Dealer is telling me he only sees a listing on the forward bushing but not the rearward bush?
    Am thinking all 4 are the same, but don't know the answer to that question.
    Hoping that someone else has already been there.
    I do know the factory bushings are different 2wd to 4wd so have ignored the listings for A/M as all the ones I have found are either spec'd as 2WD or "both".
    Supposedly lower arms are now NLA.
    Re: Lower Control Arm Bushings
    That's weird. I just looked it up in the EPC and see what he's talking about. Are you sure there's supposed to be a bushing there? Here's a snap shot of the EPC with the bushing that's shown highlighted to the right. The number on the far right indicates how many bushings there are TOTAL (both right & left sides). In this case it says 2, so that means 2 total (not 2 per side). I've never messed with these on a 4wd, so I can't help you from experience. Let us know what you figure out. Tim
    wherethevanisrare. FL
    the 4WD front lower control arm is unoptenium new. With a lot of patience and refined hunting techniques I managed to capture a driver side at the Yotayard in Denver CO The passenger side has been tracked and should be on its way to Florida soon.
    I can confirm the need of 4 bushings, 2 per arm. They are the same in front and rear of the arm, I don't know why it's not showing on the EPC.
    This what I want to replace
    This is what I scored in Denver
    Salvage yards should really be called savage yards, due to their proficiency at the use of the oxy/acetylene wrench.
    One of the bushing with a melted/ fused cam bolt still in, the other is gone.
    LG.
    Could not upload more pics, let see if a new post will let me!
    I ordered 4 bushings from www.RockAuto.com, I selected ACEDELCO part # 45G9344. I also ordered all new cam assembly, cam camber adjust#2, castel nut+ cotter pin, and other nuts and washers, from www.ToyotaPartsdeal.com. While waiting for these goodies, I went on to get the rust off the arm with the help of these guys:
    Then spray this on and in every holes and cavity to turn any remaining rust particle into neutral black oxide. It also serves as an etching primer on the rest of the part.
    LG.
    I also de-rusted, cleaned, treated,and re-greased the perfectly healthy ball joint.
    Then these guys came in. I ordered them Thursday evening, we are Monday afternoon, RockAuto realy rocks!
    The ugly black thing is the rubber part of the old bushing.
    At this point I know I have to get the bushing outer sleeve out of the arm pivot ends.
    LG.
    Die grinder and deburing bit and this is the whole bushing is out, both sides of the arm.
    Black brake calipers paint cause they leave pretty clause to the brakes, in pretty much the same environment.
    Press in new bushings with never-seize grease
    LG.
