Results 1 to 19 of 19
Thread: How to change the ignition coil?
    Van Fan AnotherUser's Avatar
    1986, 2wd
    Pacific Northwest
    Can anyone share how they changed their ignition coil without having to remove the distributor?
    If you have to remove the distributor, what is involved with putting it back on?
    1988 4 wheel drive
    Oct 2015
    california
    Re: How to change the ignition coil?
    also would like to know the process on this. I will share if i find more info..
    1987 4x4 TV.
    Hilo Hawaii
    I was wondering the same. I read that you had to replace the distributor and coil together.
    Try here. http://www.toyotavantech.com/forum/s...p?631-dead-van
    It's covered in post #15-19.
    1988 4 wheel drive
    Oct 2015
    california
    thank you originalkwyjibo. from that thread it sound like just the coil was changed. good cause I don't want to do timing
    1987 4x4 TV.
    Hilo Hawaii
    Awesome, Im swapping in my extra from my parts van. Thanks for the response and the link.
    Quote Originally Posted by vantex View Post
    It's a good idea to check timing anytime you mess with ignition components and really isn't that tough especially if you're already in there changing the coil.
    1988 4 wheel drive
    Oct 2015
    california
    I see. Possible without a timing light? Is this outlined in the manual? Basically what does set timing consist of? I just thought it was difficult from past vehicles I had.
    You will need a timing light. It is covered in the manual. Here's a couple links to check out. http://www.toyotavantech.com/forum/s...gnition+timing
    1987 4x4 TV.
    Hilo Hawaii
    I pulled mine out and replaced the coil no problem, slid it right back in to place, no timing necessary. I just matched it back to where to where I marked the cinch bolt with a sharpie. Easy cheesy, thanks guys.
    1987 4wd 5spd
    CA
    Re: How to test igniter?
    UPDATE WITH PICS: Got an igniter from JDMVANMAN (thanks!) and put it in today but that didn't get the van started. I went to test the coil per the fsm and saw this:
    Any idea what would cause this? Wondering if i need a whole new Distributor or just a coil?
    1986 Toyota van
    Sep 2016
    Tucson,Az
    Looks like you just need a coil. You can get them anywhere
    Van Addict boogieman's Avatar
    abq, nm
    kinda looks like jb weld! weird...whats the cap look like?
    1986 Toyota van
    Sep 2016
    Tucson,Az
    Or some kind of epoxy or gorilla glue
    1987 4wd 5spd
    CA
    It does haha, just melted plastic though I guess. The cap looked fine, I changed the cap and rotor not all that long ago with Toyota stuff. Duralast coil from autozone got it running. Some of those screws securing the coil as well as the distributor cap are not fun. Thanks for the moral support everyone
    Also thanks to my helper:
    1988 4x4 manual 4ye(cal) 1985 2wd auto 3y
    Jun 2018
    lummi island
    You replaced the coil without removing the distributor? I just did mine, didnt even want to try thos bottom 2 screws, just yanked the whole distributor.
    1987 4wd 5spd
    CA
    Yeah, it was really only the one next to the block that was hard. The dipstick and fuel line coming off the fuel filter create quite a puzzle. I went through 5 different screwdrivers to find the right combo of length and unobtrusive handle. A thin long 8" or so phillips would have been the ticket I think if I had one. Or one of those right angle screw drivers maybe. But yeah, the amoubt of time it took me fiddling with it I probably could have pulled the whole distributor
    1986, 2wd
    Pacific Northwest
    How to remove distributor without losing timing?
    I need to replace my ignition coil and am having a hard time accessing the bottom inner screw. It seems to be stripped out. At this point I am thinking about removing the distributor to get access to the ignition coil screw.
    What is the best way to remove the distributor and not lose the timing?
