Re: A/C, power steering, and fan (water pump/alternator) belts
I've changed that bearing a few times. It's been a while, so I don't remember all the details, but I don't think it needed any pressing. I think it just pops out and the new one pops right back in. That bearing is used a lot on motorcycles, so if Napa doesn't have one a motorcycle shop should. Good luck. Tim
Well small update . I actually managed to drill out the busted bolt and re-tap the belt tensioner .. I am going to re-assemble tomorrow and see how it looks .. I may still be interested in a replacement depending on how well it goes together if anyone out there has a lead ... but fingers crossed this goes back together and looks like it will hold up.
What's the length and thread of the long vertical bolt on the idler pulley? I remember Tim posting it somewhere but I cant find it for the life of me...
EDIT: GOT IT - M8 x 1.25 x 90
Re: Power steering belt
[/QUOTE]
Tim et al.,
Looks like the best post to add to instead of starting a new one. Having trouble with the alignment of my pulleys. Specifically the AC compressor (see attached pic). It is about one-half pulley width offset to the adjacent tensioner pulley. With the AC compressor bracket bolt-on design, it doesn't look like there's a possibility to shim anything here. Any thoughts or suggestions? I'm concerned about belt failure with such a drastic offset over a short distance. Note that the tensioner pulley and associated crank pulley are pretty close to being aligned.
More importantly, what is the pressure rating for that fuel filter, fuel hoses, and the clamps? Normal operating pressure for the van's fuel system is ~ 40 psi and that stuff looks to be only rated for ~ 5 psi. If any of that springs a leak things can get very exciting in a bad way. Especially if it blows all at once in a hot engine bay on a hot day.
Regarding the AC alignment, I didn't know it was possible, but it looks like the AC compressor pulley is installed backwards. Check out this pic from one of my parts vans:
Thanks, Tim. Fuel line is 30R7 with a 200+ psi rating, same as the remote filter (not pictured). Added the clear filter just to see what the gas looks like. Thanks for the reminder, that wix filter doesn't have a high psi rating, so I decided it was best to remove it. 👍
Thanks for the compressor pulley pick. You are correct, it's not possible to install backwards. Looks like the pulley is pressure fit around the clutch pulley core. I think it must've gotten hot and slipped back? Tried to torch it and press it back to position with no luck. Found that the '86- '88 vans offer a separate clutch pulley #88412-22030 potentially available for purchase at a few places. Still trying to figure out the difference between the '86-88 compressors vs the '89, but it's not clear. Any insight?
The extent of my AC knowledge is pretty much all here in THIS THREAD. It's a long thread (11 pages), but there is some good info and part numbers, so you should take some time to scan/review. On page 4 I made a post that shows the part number for the compressor in my picture above.
