Results 1 to 18 of 18
Thread: Adjusting or replacing front door hinges
    See THIS Library Article for an illustrated write-up on adjusting and/or replacing your Van's front door hinges, removing the front door(s), and/or removing the front "quarter panel".
    Dec 2010
    Nashville,tn
    Re: Adjusting or replacing front door hinges
    what about just replacing the pins in the hinges?
    Dec 2010
    Nashville,tn
    or rather the bushings on the pins
    1987 4wd 1985 Elegante
    Feb 2014
    NC
    That is my question also...can you buy pins and bushings anywhere for these vans? I have not been able to locate any.
    I will eventually tackle this repair as I can't see paying $80 each for new door hinges. Toyota permanently installed the hinge pins by staking them in, but a grinder and a punch is all it takes to remove them. Once the pin is removed the holes can be drilled bigger and new pins/bushings can be installed. When I do the job I'll make a post telling members part numbers and where to get them..........unless somebody beats me to it. Tim
    Dec 2010
    Nashville,tn
    I know its from february, but has anyone done this? What did you find?
    When I do mine the pins are going to be removable. No more pulling the fender if I want to remove my door. Tim
    1984 Toyota Van 2WD
    May 2014
    New York
    Quote Originally Posted by lamont View Post
    No. I have been looking for years. If you find them please post it here for the rest of us. I even looked at other makes and models for a substitute. No way.
    John
    There is nothing packaged exclusively for the van, but there are those bins at some of the bigger hardware stores that would likely have the necessary pins & bushings. Somebody just needs to figure out which combination works the best for our vans. Bronze bushings with steel pins would be preferred (as these wear well together). Tim
    '88 4x4 5 speed manual
    Dec 2018
    ME
    anyone ever crack the pin/bushing replacement discussed here?
    Got loose hinges I can live with but if there was a fix easier than the whole panel remove debacle I might tackle it.
    Van Fan Krab Krust's Avatar
    1988 toyota van 5spd 4x4
    May 2018
    seattle
    Haven't done it to the van, but on my 80s toyota truck I cut out the pins that were permanently pressed in and used bushings and pins from the hardware store that had a hole for a cotter pin on the bottom, now I have quick release doors for summer, just pull out the cotter and slide the pin out.
    Dec 2018
    ME
    yup - sound easy (ish). Thx.
    '87 4-WD 5speed window van wagon
    Jul 2017
    near tomah wisconsin
    Adjusting and changing door hinges
    1st generation (1984-1985) van
    hello,
    is this also the same procedure for a second gen '87 4WD van?
    any response is appreciated.
    Cornering light removal is definitely different. I recall that someone else used this 1st gen step-by-step said the remainder is essentially the same. Good luck!
    Dec 2018
    ME
    anyone know if you can use a set of passenger side hinges on the drivers side door?
    Looks like there may be some offset to the bolt holes (?)
    According to the part numbers, the upper left is the same as the lower right, and the lower left is the same as the upper right. So the answer would be yes.
    1987 4WD LX
    Nov 2020
    Bellingham, Wa, USA
    This question is the reason I joined this forum... has anyone figured out the bushing problem yet? Is there a compatible vehicle that we can order bushings for, or has anyone done the measurements? If there is still no one out there with the answer I can be the guinea pig I guess, but my van is my only vehicle so it's going to be me driving around to hardware stores without a door while I figure it out
    1988 toyota van 2wd automatic 1989 toyota van le 4x4 automatic
    Jan 2017
    Pico Rivera
    I am also looking for an answer I suppose cutting the old pins out and replacing with something similar would work? Did anyone ever end up doing this?
