As some of you know I put my van through severe service. I carry a heavy fixed load of around 3,000 lbs & I often tow a small covered utility trailer. I put air shocks on this 86 LE back in the 90's, but time and stress have taken their toll. Both shocks were leaking oil and would no longer hold air. Even when they did hold air I was asking a bit too much of them (inflated to 125 psi they couldn't quite lift it where I wanted it to ride). Then there's the question of stress on the shock mounts. The vans with coil springs have solid shock mounts, but it's still a lot of pressure in a small area. Here's a picture of my van I took yesterday (notice how low it sits in the back).
So I've been looking for replacement air shocks but could find none that said they'd work on a van. I ended up taking measurements and based on that I finally found some that fit the bill. The ones I got are Gabriel 49203 Hijackers Air Shocks - 2 Pack.
I'm not going to elaborate much on the shocks because they're pretty much a direct swap over. Being air shocks they will require running of air lines, but they come with instructions and it's pretty easy to figure out. The only "hiccup" with the shocks was the diameter of the "can" (at the very top) is a bit big & the mounting stud was too long. I compensated for that by simply using 2 of my old rubber mount bushings in place of the one between the shock and the body/frame of the van. With 2 bushings it made the stud slightly too short (had trouble getting the nut started), so I ground a little off the rubber bushings and that did the trick (sorry no pics).
In addition to new shocks I decided to put air bags inside the coil springs. My research narrowed these down to 2 choices. I could use Firestone W237604112 Coil-Rite Kit or AIR LIFT 60812 1000 Series Rear Air Spring Kit. As an RV tech I install Firestone air suspension products and am familiar with them, so I chose the Firestone Coil-Rites.
I didn't take pics of removing the springs and old shocks, but this is all straight forward and easy. 1st thing is to jack the van up in the back, then put jack stands under the frame (not the axle). I used the forward mounts of the lower control arms to support the van. With jack stands secure, I lower the rear axle until it's hanging on the shock absorbers. With the jack still under the differential, I remove the shocks, then drop the axle as far as it will go without stressing the rubber brake line. With the axle in this position the springs lift right out.
In order for the air bags to fit this rubber stop needs to be removed. It's got a hole in the center and a 12 mm socket with extension will fit inside to remove the mounting bolt.
To prevent things from becoming a big mess, I throw the springs and rubber isolators into my garage sink and remove the road grime. When clean I cut a short piece of 1/4" air line and shove it into the air bag.
Next I take my Mitivac hand vacuum pump, slip the hose over the air line, and suck all the air out of the bag.
This is required because the air bag is too big to easily slip down inside the spring.
With all the air out the bag can be folded over and easily slipped inside.
Once in position I lube the spring & bag up with Dawn dish soap and remove my vacuum pump (note: not all dish soap is the same. Some have harsh chemicals that may damage parts of the bag. Dawn is mild (no lye or ammonia), so this will not hurt anything. Lubrication is helpful as it will allow bag to slip into position as it fills with air and unfolds.
Bag is slightly inflated to help it unfold completely.
This is good. Bag is now positioned correctly with no folds or twists.
I put my pump hose back over the bag inlet just to keep water out & rinse all the soap off the spring & bag.
Next I trim the air hose. I'm going to use this little piece to help me lay-out the air hole in my spring mount.
Next I put the lower insulator back on the spring mount.
While carefully holding the spring in it's normal position, I look to see where the air line is touching the spring mount & make a mental note on location. (sorry, couldn't get this to show in picture).
Spring is removed and location is marked.
I drill a 3/16" pilot hole.
Followed by a 1/2" hole.
It's important there be no burs or sharp spots on this surface. I use a sanding disc on my die grinder to make it smooth. After the sanding disc I smooth it with Scotch-Brite disc.
I apply some Rustoleum for protection.
Air line is removed and plastic puck is set in place.
Spring is installed and hole is inspected from under side to ensure it's lined up with air bag inlet.
Air line for final assembly is inserted into air bag.
Air shock is installed and air lines are plumbed. Since this van was already set up with air shocks, the 1/8" lines were already run. I decided to plumb the air bags into this same air line (less work). I put together a tee for each side that will share available air with the shocks & the bags. For the passenger side, the spare tire rack support is the ideal place to mount.
All of the above steps are repeated on the driver's side. The driver's side is a bit more cluttered & there's the hot exhaust to consider. I choose to mount my tee on the panhard bar support.
Vehicle is taken off of jack stands and air suspension is inflated to 30 Psi. Here is a view from underneath of an inflated air bag.
And here's all the weight being carried by these.
And here's my new ride height
FYI, I looked under a couple of my 4wd vans and all suspension components appear to be identical to the 2wd (at least on the rear). I can't speak from experience, but I believe these same parts will also fit a 4wd van.
Disclaimer: I am posting to show what I have done to my van. I am not advocating anybody else do this. Any time you work on or modify your vehicle you do so at your own risk.
WARNING: The LSP & BV (Load Sensing Proportioning & Bypass Valve) relies on factory spring rates. By lifting a van in this manner you'll essentially be disabling the rear brakes. Since I carry a heavy fixed load, I was able to compensate for this by lifting my LSP & BV lever to it's maximum height & permanently fixing it there. For more information on the LSP & BV CLICK HERE.
